Question about Superview 890 DVB-S Satellite
Putting chanels in right order
I am un able to put the channels in there right secquence eg channel 1 is on channel18 . Thanks.
How do I change the Chanel numbers on my technomate
sorry but you can not renumber channels .
Oct 01, 2016 | Televison & Video
Hello! We have some problem whith 1 chanel, when 2
BOTH turntables and the same channel on each? If it's really really low and tinny that would probably be a failure to have/use a PHONO preamp (built-in and selectable on the Mixer).
Swap the channels coming in from the mk1200 and see if it stays with the mk1200 or with the left channel of the mixer.
There IS an outside chance you have flaky connections at the cartridge.
May 06, 2011 | Vestax Pmc07pro DJ Mixer System
I have a crown 602 channel 2 shows signal coming in, but no volume comes out. Yet when its bridge it seems to put out more power than just one chanel. Not sure where to start looking into the #2 channel...
Common problem. Power transistor in channel#2 is weak or out completely.
Bridging converts from 2 channel(stereo) to mono and you are are useing both channels in series to effectivley double your output.
Oct 04, 2010 | Crown XLS 602 2-Channel Amplifier
When I click chanel up or down the tv says please
For the Dynex ZRC-102 remote control channel switching.
1. Press the MENU button and select SETUP.
2. Go down the list and select FAVORITE CHANNEL MODE and switch it to OFF.
The +/- CHANNEL buttons will then switch channels when pressed.
Sep 28, 2009 | Televison & Video
My 60'' LXI slimview television will only save one chanel.
If you have remote control for the channels on your set, try to push menu then choose "memorize channel" or choose "cable" then do the channel memory.
Thanks.
Aug 16, 2009 | Televison & Video
Doesn;t show itv 1 or channel 4
edit your inputs and make sure itv1 has't been put on skip
your channel 4 could have been automatically deleted if you did an auto program on the channels.
Poke around in the menu and you should be able to tell it to display channel 4
Oct 09, 2008 | Sony Bravia KDL-42V4100 42 in. LCD TV
I put the wall cable to the vcr and the cable to the tv to the vcr, and i put the vcr on channel 3 and want to record channel 31, it records channel 3
you state here you put the vcr on chanel 3 but you want to record 31. put the vcr on chanel 31 to record
Aug 01, 2008 | Televison & Video
Dbox 2 Neutrino Virgin blocked channels (Cable)
Anybody know how to get the movie chanels back on my dbox, most chanels seem to be there the code is right just black screen where there should be movies
Apr 18, 2008 | Televison & Video
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Superview 890 DVB-S Satellite Logo
Top Superview Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Superview Audio Player and Recorder Expert? Answer questions, earn points and help others
