Question about Samsung SPP-2020 Thermal Photo Printer
Red light flashing
Around the power button a red light flashes when I go to print?
frcs68
  • 1605 Answers
SOURCE: lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Posted on Apr 17, 2009
frcs68
  • 1605 Answers
SOURCE: my printer has two flashing lights
try to rest the printer by opening the front cover (not the paper tray) and closing it again.
xptareq2000
  • 1447 Answers
SOURCE: red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Posted on Aug 18, 2009
SOURCE: I have Samsung ML-1640 Laser Printer, but it won't
A.o.A
All the dears when I print with Samsung ML-1640 there are lines in printing Kindly send me solution of this problem.
Posted on Jan 05, 2010
pineworks
  • 4041 Answers
SOURCE: Flashing Red & Green lights - Samsung ML 2510
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Posted on Jan 30, 2010
No red light or power
I've had about 3 or 4 similar sets like this....all have had a flash-over around the bridge rectifier to metal chassis. (you will clearly see the flash-over on the metal chassis). Clean back the print re-solder bridge rectifier,fit a new fuse (usually around 4 to 6.3 Amp)
Feb 15, 2014 | Samsung LN32A330 32 in. LCD TV
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
May 15, 2010 | Zebra TLP 2844-Z Thermal Label Printer
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
The light on the right is flashing red.
d40a83b.jpgCancel button
0de392d.jpgPrint cartridge status light
84e6616.jpgResume button and light
e1e1095.jpgPower button and light
- If the power light is flashing it means that your printer may be receiving data.
- If the resume light is flashing you may be out of paper, or you may have a paper jam, you may be printing a two sided document by hand and the first side has finished printing.
- If the print cartridge status light is flashing that means the top cover may be open, of there may be a problem with one of the cartridges.
- If all of the lights are flashing the printer may need to be reset.
Hope this helps.
Jan 06, 2010 | HP DeskJet 932c InkJet Printer
Flashing red light
if its three of one red light, its broken and youll need to send it to microsoft for repair
Dec 30, 2009 | Microsoft Xbox 360 Console
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  2. over temparature
Aug 04, 2009 | Samsung ML 2010 Laser Printer
Flashing red "check ink" lights and nothing is wrong with ink
Is there a resume button on the printer? If so press this, often printers will allow you to bypass a low ink message and print for a while longer.
Jun 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Samsung SPP-2020 Thermal Photo Printer Logo
29 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
