-   Yeah, me too. Please tell me what to do. I got real cold so I decided to turn the air down. Well, none of the buttons would work. I couldn't even turn the damn thing off. So, I just unplugged it. Then when I plugged it back in, it would NOT work at all!!! What the hell happened??? When I plug it in each time, all I get is an "E1" in the termostat window. This is ********. Please help! I can't live without air.-   rollz8ball
Jun 13, 2008
-   yea i have the same problem, i see E1 error code and i cant turn it off and on and it will run for 3 minutes
i have the exact same problem-   Guest
Jun 09, 2008
-   I get the E1 error. I turn off the AAC unit and unplug it but it will run for 3 min or less and same problem. I have cleaned the filter very well! I do not have the book of instructions and error codes.
Unplug it. Wait a few minutes. Hold in the Power button while plugging it back in and keep the button held down until a beep is heard (~5 sec). Unplug the air conditioner, then plug it in again. Note: some units require using the Mode switch, rather than Power.
Is it possible you still have the owner manual? It will have the reset codes for you listed. Also, check the filter, make sure it is clean and that the evap and condenser are clean as well.
I read on another site that there is no solution. Word for word the person stated that the damn thing was "fried." and to take it back. Not sure what he meant by taking it back? Certainly he was prematurely assuming that the AC unit was new. Well, mine is not new. Actually, I bought it a year ago today, and it blew out today. Tomorrow it will be out of warranty. Imagine that ****!! I have owned 3 AC's in the last 5 years and each time they blew out, it was on July 15th, which is also my birthday. Three birthdays ruined by this ****, and then this is even speaking of the ODDS of this happening three times on the same day. Come on now, where are my lottery winnings???
Your power botton went bad. I took the circuit board out and chanded the timing switch with the power switch and the E1 went away and the AC unit works fine now.
I have a 10 inch Sear outdoor RUUD Thermopump. The coils are collecting frost, I hear it making some...
(More)
I have a 10 inch Sear outdoor RUUD Thermopump. The coils are collecting frost, I hear it making some knocking noise for just a short period of time until it stops and starts running normally. It stop before I could get out to realize the source of the noise. Any suggestions until I get a service maintenance on this unit? The house is being heated.
ac sensor can not be used, I've tried to replace the sensor, could be just 10 minutes and then die...
(More)
ac sensor can not be used, I've tried to replace the sensor, could be just 10 minutes and then die again what should I do?
How are you guys Thanks for answering my question if an air condition not work and all the diods in...
(More)
How are you guys Thanks for answering my question if an air condition not work and all the diods in the indoor are worked together how can repair it. thanks again and i'm sorry about my english if you don't understand because my english not good.
