Question about Vehicle Parts & Accessories
Renault laguna gearbox
Gearbox will not go in to drive
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Vehicle Part... Master
  • 1,449 Answers
Check for worn linkages
Posted on Dec 03, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Renault laguna start problem
SOUNDS LIKE THE CLUTCH FRICTION PLATTE NEEDS REPLACING - YOU MIGHT BE LUCKY THOUGH AS SOME OF THE RENAULTS HAD A CLUTCH CABLE WHICH MAY HAVE BROKEN OR BEEN OVER STRETCHED, THIS IS A MUCH CHEAPER AND EASIER JOB TO DO & ANY COMPETENT PERSON CAN CHANGE IT
Sep 02, 2012 | Cars & Trucks
MY AUTO BOX ON MY LAGUNA 3.0 SLIPS FROM PULLAWAY WHEN DRIVEING
if its slipping when pulling off, or under load this most likely is the forward clutch pack, however on earlier boxes up to around 2000/2001 these are not sealed units and having the oil and gearbox filter changed may help remedy for some time, but this is usually a sign off gearbox failure coming soon.
Aug 30, 2010 | 2002 Renault Sportwagon
Renault megane scenic 1.6 e automatic
when driving my renalt laguna turning left or right a noise appears
Apr 12, 2010 | 2003 Renault 181
Whining noise in 3rd and 4th. 2004 laguna 2l tdi 130K
Its the thrust bearing on its way out,or the gearbox. could last for months might go tommorow. inside the gearbox get the thrust bearing checked first its cheaper!
Jan 16, 2010 | 2005 Renault 18I
How to remove the starter motor from a renault laguna
dissconnect battery first. the starter motor is connected to the gearbox facing into the flywheel you need to remove any connecthions that are on the back of it then remove the bolts that go through it that hold it on give it a little shake and it should come off.
Oct 18, 2009 | 2000 Renault 181
How to change clutch on renault laguna 1.9 estate
buy manual specific to vehicle online or at auto parts store
Sep 20, 2009 | 2005 Renault Sportwagon
Renualt laguna 2000 running very juddery when idling
Look or listen for a vacuum leak. Brittle hoses or ones that just break off.
Feb 25, 2009 | 2000 Renault 181
Car radio code
I had a Laguna before the gearbox packed up. Nice car but a really bad gearbox. My radio was the same. What I used to do to get it going again was disconnect the battery and thereby power it down completely. After I reconnected the battery it allowed me to reenter the code as described in the radio manual.
Happy listening, with the radio on you wont hear the gearbox tearing itself to pieces.
Sep 30, 2008 | 1986 Renault Sport
RENAULT LAGUNA.
check your linkages and shifter problem may be also in the gearbox
Jun 02, 2008 | 2003 Renault 181
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
