Question about Nokia E5 Cell Phone
Shuts down shuts dowm when i make a call??//
  • Nokia Master
  • 2,148 Answers
Hello, as far as I know and at the same time it is very funny.I to astonished but it is true.Just change the earspeaker (earpiece).This works perfect.This problem comes from the short circuit of this small component.Try it now and you will see the result.This answer is offering you according to my experience.Good luck.
Posted on May 05, 2013
My screen stopped working and it won't let me get on anything
shut dowm comp by holding of button down thn reboot after 20 seconds keep taping the F8 key when gisplay comes up select restore to earler time with system re store
Oct 07, 2013 | Audio Players & Recorders
How do I get it to down load windows? When I shut down It says installing updats 1 of 2 for about 1 hour and than 2of 2 for another hour every time I close down.
This can be due to faulty errors that have crept into the operating software and it could be that some registry files are missing or corrupt. If you have a recovery disc, then it can be installed and the software corrected. If not the OS must be reinstalled. Also check for virus and clean up the PC from unwanted files specially the browser from cookies and search history.
Jun 28, 2012 | HP Nc6230 Laptop Computer Lap Top Notebook...
Unable to exit sFE MODE ON AN ACER LAPTOP
Hi
please explain a bit more to us what is happening have you just left the laptop running
have you tried going through normall shut down
or
just holding dowm the power button for a few seconds
or
is the laptop not running correctly
Jun 18, 2011 | Acer Aspire 4315-2490 Notebook
Computer will not start up only sometimes after it sits for days but after shut dowm wont start up again
Try performing a hard reset on the laptop by removing the battery, unplugging the Power Adapter and disconnecting external devices connected to the laptop. Once everything is removed/disconnected, press and hold the power button for around 15 seconds. Put everything back then power the PC on. The reason this issue happens is because the computer doesn't shut down properly and because of this charges get left on the laptop's motherboard, holding power button down with nothing connected to the PC drains these charges. If still the same issue exists, try updating Windows, there might be updates that doesn't install completely. Update drivers as well and run a system scan with your security software.
Hope this help. Goodluck!
Mar 29, 2011 | Dell Studio 1537 Laptop
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
Laptop shuts down at random times it sometime shut dowm within 5 minutes i use or can stay on allday but now it shuts down within like 20 minutes of use.please help
I THINK ANY VIRUS MAY BE IN YOUR SYSTEM. PLEASE FULL SCAN YOUR COMPUTER THROUGH A GOOD ANTIVIRUS. IF PROBLEM REMAINS SAME THEN YOU HAVE TO CHOOSE FORMAT WINDOW AND THEN REINSTALL WINDOW.
Sep 30, 2009 | Sony VAIO VGN-AR630E Notebook
Not shutting down afer reporting scanner error
I have hp printer model R45
I got scanner error and printer asked me to turn power off and on. I turn the power off/on. Its about a month the Problem has started
Please HELP
Thanks
amin
Apr 21, 2009 | HP OfficeJet R45 InkJet Printer
Check SP wires
There is an internal short that is being detected. This is probably a defective output transistor that is somewhat sensitive to heat. This should be a straightforward repair with a parts cost in the $20 range. Add in the local labor rate for the total cost.
Dan
Jul 16, 2008 | Yamaha RX-V740 Receiver
Shut down after 30seconds
There has been a similar question, which was answered by kimi here: http://www.fixya.com/ThreadView.aspx?thid=101354&prdid=231850 Hope this helps.
Jan 26, 2006 | Panasonic PT-56TW53 56" Rear Projection...
Nokia E5 Cell Phone Logo
88 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
