Question about Manufacturer Steiner Olive Drab Gi Military Marine 8x30 Binoculars
Steiner binocular repair
Lens out of adjustment, gives a double image.
Lens alignment
generally under the edges of the covering at the eyepiece end there are tiny screws that are used to adjust the prisms in the binoculars, generally out of alignment issues are caused by the prisms being out of alignment.
Apr 16, 2014 | Celestron Tripod/Wedge NexStar 4GT/5i -...
How do i tighten the swing action on my stiener safari binoculars?
These binoculars have a 10 yr warranty, so you may contact steiner (http://www.steiner-binoculars.com/) for repair for a nominal charge, however there is an easy fix: You'll need a small (about 1/4 in) screw driver.
1. remove the objective lens protector. This is the small metal piece on the binocular side that is loose, opposite from the eyepiece(part you look through). It appears impossible to "pop" loose from the outside, but if you slip your finger inside(try not to smudge the lense), you'll feel a significant ridge. You may be able to pull / pop it off with your finger, or a small handle.
2. Tighten the screw that is now exposed. Do not overtighten, just a little tighter than what it takes to keep it from "falling" on its own weight.
3. Pop the lens protector back on the object lens.
Oct 19, 2011 | Steiner Safari Binoculars
Have lost rubber eye piece off Steiner binoculars. How can I get a replacement. They are a compact pair taht we have taken on holiday each year. Name on binoculars says that they are 8 x 22...
need the rubber eye piece for 7x 50 jason/empire binoculars and also the one steel rim that goes under the eyepiece. I would appreciate any help that you could give me. thanks
Mar 29, 2011 | SteinerPredator8x22 Binoculars
Where do i find the model number on my steiner binoculars?
The model of Steiner binoculars is on the plastic plates on the body. On earlier models mainly the green rubber covered military types is is molded at the front of the body near the objective lenses. These were called the Military/Marine and are of a different specification to the current Military/Marine. The original were a military bincocular which has more in common with the current Steiner Military. If you are after the serial number it is located on the front metal disc between the binocular barrels on a porro prism binocular. A porro is where the objective lenses are spaced further apart than the eyepieces. On a roof prism Steiner the serial number is located underneath between the two barrels on the hinge. Roof prisms are binoculars where the objective and the eyepieces are in line. If the serial number is a 10 digit number the 1st and 3rd numbers will give you the year of manufacture.
EG: 9042577777= 1994
If it is five or six digit number then it is the 1st and 2nd numbers
EG: 871245= 1987
Jul 24, 2009 | Steiner 8x30 Binocular
I see double one over the other about 20 degrees
Up close to the eyepieces around the barrels are small screws that you can use to "collaminate" your binocs. The screws aren't meant to be accessed by the owner and most manufacturers cover them up with the material that surrounds the binocs. Of course the binocs in their current state are useless anyhow, so I wouldn't hesitate to peel up the material to look for the screws. If you do it carefully, you can reseat the material anyhow. Then once you locate the small screws, put the binocs on a stand or a table outside. Focus on something far away using one eye. Then using both eyes, you adjust the screw on the other eyepiece while looking through the binocs. Adjust until you get a single image. You can use loctite, or nail polish to "glue" the screw in the final position if it is really loose.
Apr 23, 2009 | Steiner Tasco Offshore 54 Binoculars
Double image - one above the other
yes , they have to be realigned, if you want call me and we can talk further 5088331232...larry
Apr 22, 2009 | Steiner Tasco Offshore 54 Binoculars
Need replacement parts to steiner safari 8x22 eyecups
www.steinerpartsdirect.com
They are Steiner authorised. Binoculars.com used to list many Steiner parts as well.
Feb 28, 2009 | Steiner Safari 224 (8x22) Binocular
Steiner Commander Compass not working - possibly low of fluid?
Check this post for lens covers.
http://www.bluewaterweb.com/MarineHardware/Hardware.asp?
Feb 15, 2009 | Steiner Military/Marine 7x35
Binoculars
Gently squeeze the two barrells together (they should be able able to do it easily). I believe it's called the interpupilar distance. If you can't get the binocs to do it, take them back to where you bought them.
I admit I bought a cheap pair on the internet on which the barrels do move, but they don't get close enough to totally eliminate the double vision thing. No wonder I got them at a decent price.
Jun 22, 2008 | Steiner Genuine G.I. 7 x 50 Binoculrs with...
Manufacturer Steiner Olive Drab Gi Military Marine 8x30 Binoculars Logo
420 people viewed this question
Top Manufacturer Home Experts
john h
Tom Chichester
Are you a Manufacturer Home Expert? Answer questions, earn points and help others
