Question about Polaroid t1031 Digital Camera
Lens stuck i accidentally dropped it and its open..then the lens was stuck wat wil i do
  • Polaroid Master
  • 32,281 Answers
You need ti take it to a digital camera repairer for repairs.
Posted on May 05, 2013
Samsung Digimax S800 has lens stuck in open position. Replaced with fresh alkaline batteries, pressed on button, screen lit up for a second or so, turned off and gave 3 beeps. Any ideas? Thanks, Kevin
Did you accidentally drop it? If you did then there is a big chance that the lens is busted. If you didn't drop it, then it could be just dust/dirt inside the lens mechanism. Hold your camera with the lens facing the ground and then repeatedly tap it your camera gently - moderately to remove the dirt. You can also try spraying compressed air into it.
Sep 07, 2011 | Samsung Digimax S800 Digital Camera
My lens is stuck open, every time i try to turn it on a lens error message pops up then quickly shuts down, wat can i do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 29, 2010 | Nikon COOLPIX S200 Digital Camera
When camera turned on it says lens error and then shut down
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
My camera was stuck with an open lens and saying ?lens error, restart camera.? I banged it against my hand a few times, the lens retracted and all seems to work as it should now. Thanks for the post!
Dec 18, 2010 | Nikon Coolpix S3000 Digital Camera
The camera lense is stuck open and not will close
Hi! Better check it with qualified technecian. It might damage everything if you force it. The lense broke inside. It needs to be replaced or adjust the screw to lossen so that lens will go back to its original position.
Please feel free to comment.
jonags3
Jul 19, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Lens Stuck
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Mar 17, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Lens stuck open ,
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 04, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Sony DSC-P100 Lens Will Not Open - Dropped Camera
Motor mechanism is shot Sony customer support for advice My - bet? New Camera And treat this one with some TLC
Aug 21, 2006 | Sony Cyber-Shot DSC-P100 Digital Camera
Polaroid t1031 Digital Camera Logo
41 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
