Question about LG Cell Phones
Lg stuck in headset mode - LG Cell Phones
  • 1011 Answers
SOURCE: my LG U8330 is stuck in headset mode
Dear,
turn off ur phone by removing battery and turn it on again and then change the mode of it.
regards,
dont forget to rate it as it will fix the issue
Posted on Feb 23, 2009
SOURCE: LG C1500 phone is stuck on headset mode and no headset is in it.
PERSISTANCE IS KEY!
My Palm Centro sat in a small puddle for a few seconds, and the only thing that was wrong was that it was, like every other poster here: Stuck in Headset mode. For 3 days I read posts / forums all over the place, getting similar ideas about inserting/pulling out the speaker cord rapidly / soft or hard resetting / pulling out at a certain point etc etc.
The real problem was that inside the 2.5mm jack there is a little microswitch that enables / disables the headset function, and if it gets stuck open- nothing can override it. --- Again --- 3 full days of twisting, pulling out, screwing with the jack and wasn't able to get anything out of it- was about to say screw it.
THE ANSWER!!! -- I read somewhere that using a Qtip could increase my chances of snagging the switch down; I doubled my odds and sprayed the **** out of it with WD-40 (with the fore-idea that the switch got all gunked up and is stuck in the open position)
--To test it out, start playing a music file or anything that should originally go through the main speaker (or just call your Voicemail)
-- I got the tip wet with the wd-40, and since I have a 2.5mm jackport (not even the qtip stick fits in the hole) I started twisting the cotton off of the stick into an elongated portion of the wet cotton; long enough to fit in the port. I stuck it in (twisting in the same fashion as the twisted cotton) and just started twisting. About a minute worth then I yanked out and-- WaLaa! MUSIC
Only thing that worked in 3 days; I figure the individual cotton strands snagged on the thing and pulled it down, although I contribute it finally moving to the WD-40.
GOOD LUCK =)
Posted on Apr 05, 2009
SOURCE: LG shine stuck on headset mode
reset the phone or cntuck to lg care
Posted on Apr 10, 2009
  • 55 Answers
SOURCE: Nokia 6085 is stuck on headset-mode. How can I
try this: get a headset connect it then disconnect it go to settings - profiles - and select another profile. If it doesnt work try to restore factory settings if you dont know the sercurity code it should be 12345 by default
NB: pls vote
Posted on Oct 24, 2009
nightlisa
  • 102 Answers
SOURCE: my LG Voyager stuck on headset mode
Turn your phone off and remove the battery. Also tap the headset port (where a headset would normally plug into).
When you reboot it back up it should fix itself. If it doesn't you have a hardware problem (its physically broken) you can see if its under its 1 yr warranty to get your free replacement, or if its older - there's always cell phone insurance.
Posted on Jan 07, 2010
Lg shine stuck on headset mode
Try connecting your headset again and then disconnect it after a few seconds. I think there's just an issue on the headset outlet.
Hope this helps! -jayps
Mar 16, 2011 | LG Shine KE970 Cellular Phone
No sound in my lg led tv. it says sound in head set mode
May not be a solution, but I would try plugging in a headset into the jack several times in and out. There may be a stuck mechanical part in the jack which informs the main board that there is something plugged in. While the head set is plugged in check if there is sound in the headset.
Techdaddy2Go
Nov 11, 2010 | LG 32LE5300 Widescreen 32 in. HDTV
My lg ryhthm phone got wet and now its stuck in headset mode
Your phone's headphone jack port is shorting. Try turning the phone off then dry it with a hair dryer for 5 minutes. Turn it back on and see if it helps, if it doesn't well you now have a permanent damage on your phone, its probably the headphone port controller, its busted...
Jul 14, 2010 | LG C1500 Cellular Phone
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
My LG Voyager stuck on headset mode
Oct 28, 2009 | LG VOYAGER VX10000 Cellular Phone
Apr 10, 2009 | LG Shine KE970 Cellular Phone
My lg u8330 is stuck in headset mode and wont turn off
Dear,
regards,
Feb 21, 2009 | Cell Phones
No audio
wife had similar problem. local verizon store technician asked her if she used a headset - when headset is used external audio is muted - seems, somehow, the phone was "stuck" in headset mode even after the headset had been removed. solution was to re-plug in the headset and remove is slowly. hope this helps.
Feb 03, 2008 | LG VX5300 Cellular Phone
My lg hbm-730 headset is stuck in pairing mode
I have the exact same problem. I suggest you flush the LG piece of **** down the toilet, and never purchase from LG or bluetooth again.
Sep 09, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Cell Phones Logo
23 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
