Question about Pool & Spa
How do i turn up temperature on my spa?2 - Pool & Spa
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
Press the red button that says "warm". WOW
Posted on May 09, 2013
On leisurerite spa pool what does code 1-3 mean
If your system is equipped with a circ pump, it may be configured to work in one of three different ways: 1)
The circ pump operates continuously (24 hours) with the exception of turning off for 30 minutes at a time
when the water temperature reaches 3°F (1.5°C) above the set temperature (most likely to happen in very
hot climates). 2) The circ pump stays on continuously, regardless of water temperature. 3) The circ pump
will come on when the system is checking temperature (polling), during filter cycles, during freeze
conditions, or when the blower or another pump is on.
Dec 06, 2016 | Pool & Spa
My spa temperature light is blinking. It is set at 104 and the temperature is showing 118. Why is the temp blinking?
If you can contact your spa manufacturer they will usually send you the manual for your unit at no cost.
If the temperature is set at 104 it is at the high end of the safe temperature for a human. 102 is recommended, and 103 is OK for 15 to 20 minutes maximum.
If your spa is actually at 118 degrees, it could easily cause very severe medical heat distress. I would strongly recommend NOT using it until you can get the temperature down.
It's possible that the blinking light is a warning.
Jun 14, 2015 | Intex Pool & Spa
The instrumentation panel says "SL" and the spa isn't heating.How do I get it to heat again?
You have it in "Sleep" mode. Spa will not heat normally in this mode...
If the SL Message is Alternating with the Water Temp in the Display Screen (we call this "Flashing Sleep"), the Spa is Operating in the Sleep Heating Mode.
If the SL Message is ON Solid (Not Flashing) in the Display window of the panel, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
SL or SLP is one of the Modes you can program your spa into:
EC - Economy
ST/Std - Standard
SL/SLP - Sleep
It is advised you keep your spa in Standard mode. Push the Jets button then immediately push the light button. Each press of the light button will scroll between these three modes.
Good Luck
Aug 27, 2013 | Balboa Instruments Duplex Digital Panel 2...
A downeast hot tub water is only 78 degrees turn up to 100 doesn't never get warmer and shows a ECn code
Check your filter cycles and switch spa into Standard Mode as you have it in Economy. (In Economy mode it will only heat during the filter cycles).
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Apr 06, 2013 | Washing Machines
My Marquis Randezvous Spa won't heat
It's one of 2 things. If the jets turn on but no heat, you have a bad pressure sensor or temperature sensor. If the jets don't turn on you have a bad pump.
Apr 02, 2013 | Pool & Spa
On my hot tub control panel Balboa M1 is the code Ec?
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
Mar 13, 2013 | Balboa Instruments Pool & Spa
Hot tub in EC with light flashing
Ecn or Ec Message
Ecn or Ec Message
Dec 23, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
How do I turn on the heat and the spa in the pool?
You must first make sure the filter pump is on and running (primed). If you have a pool spa combo, you will need to turn on the heater by making the desired temperature higher than the current temperature. This is a call for heat. You must then move the suction and return valves to **** and return to the spa. This is accomplished either by moving the valves manually or by putting it into spa mode if you have a control system. You didn't say whether or not you have a manual or automatic system.
May 18, 2010 | Hayward H Series Pool & Spa Heater...
Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
Aug 11, 2009 | Jacuzzi Home
Pool & Spa Logo
18 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
