Question about GE DBXR463GB Gas Dryer
Strong odor after staining floors
I am getting a strong odor when I run may GE gas dryer ever since we had our wood floors (one floor above) refinished. Two different repair companies told me it is from the stain fumes and we just have to wait it out. It has been 10 days since the floors were finished. We have been blowing fans, keeping windows open and are still getting the odor when the dryer runs. Help!!!
    Novelist:
  • 159 Answers
If the oder is in the air through out the hose the dryer uses the same air to heat up to dry the laundry. so if you still smell it al around your house you will smell it from the dryer because its the same air.
Posted on Aug 10, 2007
  • 20 Answers
Is it possible that some finishing paint or what not have leaked onto the venting? And every time your dryer is turned on the venting heats up and evaporates the finishing stuff? If it is a considerable amount then it may take a while to completely eliminate the odour.
SOURCE:
How to stain a solid wood floor
They have paint on it.If have it you have to remove old paint.Some place have machine to remove old paint you can rent.Then put new stain.
Apr 10, 2013 | Sub-Zero 611 / O Bottom Freezer...
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
What is laminated Floor?
Basically, laminating is the result of a direct pressure process that fuses four layers into one durable surface. The laminating technique originally came from Europe and spread worldwide in the last decade.
There is a srtrong odor of gasoline or maybe brake fluid whenever i start and run?
Sounds like two different problems.
I would have the engine computer checked for trouble codes and the body computer for ABS codes.
The brake problem could be the master cylinder, the gas smell could be a fuel leak or a problem with the venting system for the gas tank.
Sep 03, 2012 | 1999 GMC Yukon
I have a 30,000 btu ventless mr heater for two months it has run with absolutely no smell,the other day I did some wood staining, now the heater has a strong co2 smell is their any way to clean the heater...
Sure is. Never operate a vent-free gas appliance (not even the pilot light) while painting, staining, cleaning carpets, etc. It picks up the odors and will not burn the odor off, because the odor doesn't get in the heater, it just makes the odor worse. You will need to turn the heater off and not use it, until ALL of the odor from the staining have completely dissipated . It may take a week or more, even though you may not be able to smell the odor from the stain, the warm moist air from the heater will activate it again. If you get a warm day soon, open a window or two and let the fresh air in. That will help dissipate the odor. But, allow a week minimum, before trying to use the heater again.
Oh, by he way, that wasn't co2 you were smelling. co2 is dry ice. It has no odor. Just like co (Carbon Monoxide) it has no odor. You were smelling the fumes from the stain. Just 50 times worse.
Good luck to ya,
Rich
Mar 02, 2011 | AOC Heating & Cooling
Burning chemical smell coming from the gas dryer
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
heatman101
May 28, 2010 | Kenmore Elite HE4 Electric Dryer
After drying, clothes have a soured smell. I really don't think its the washer because there is not a smell there. However, I have run just bleach several times through the washer and have tried candles...
Questions
Gas or Electric dryer?
Is the odor there even when not running?
Have you recently done any painting or stain/shellac in the house recently? Home perms?
Gas dryers will often give clothing a kerosene like odor if the above conditions have occurred. Any sprays or aerosols can have the same effect. Unfortunately only removal of the culprits and time will alleviate this.
Jun 08, 2009 | Whirlpool Dryers
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Amana Dryer Omits Kerosene like odor
it sounds like the orifice is gone bad
Jun 28, 2008 | Amana Dryers
GE DBXR463GB Gas Dryer Logo
196 people viewed this question
Top GE Dryers Experts
vince
gbob59
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
