Question about Adidas Mens RESPONSE ADP3017 Black Resin Quartz Watch with Black Dial
Adidas adp3017 Not able to set time,
3 Suggested Answers
small6363
  • 18424 Answers
SOURCE: DON'T KNOW HOW TO SET TIME ON ADIDAS ADP1863
go to the link below for instructions
http://www.adidas.com/campaigns/watches_fw07/content/performance/pdf/performance_en.pdf
Posted on Oct 01, 2012
Not able to set time in my adidas adp3017, kindly help me
Posted on May 04, 2013
I can't set time on my adidas BI1333 watch.
Try Googling (Adidas)(BI1333)(manual) without parens to get instructions.
Aug 31, 2017 | Adidas Watches
How to set time on polar rs300x
Access watch settings scrolling by UP/Down button.
<Settings> <Ok> <Watch> <Time and Date Settings>
In Time Settings:
Set the local time (Time 1) and a time difference to it (Time 2).
With Time zone, you can select which time zone is used.
In Time view, you can easily change the time zone from Time 1 to Time 2 by pressing and holding DOWN.
Set the date with Date setting.
You can also download the user manual from the link below
http://www.polar.com/e_manuals/RS300X/Polar_RS300X_user_manual_English.pdf
Oct 06, 2015 | Polar RS300X Watch
How do I turn off the hourly chime
Generally the chime is turned on or off by pressing a combination of two buttons. If you don't have the instructions that came with the watch, then perhaps you can figure it out with a little trial and error. On watches similar to yours, pressing two buttons at once changes functions such as 12/24 hour time, turning the alarm or chime on/off, switching the day/month in the date display (ie. 12-6 to 6-12), etc. You will just have to figure out which combination turns the chime on and off.
Dec 06, 2012 | Adidas Mens RESPONSE ADP3017 Black Resin...
Can't set the digital time on Diesel DZ721
here are instructions from diesel:
http://store.dieseltimeframes.com/wcsstore/CommonDiesel/instructions/ENGLISH/Diesel_Digital-Guide_ENG.pdf
more specifically
TIME OF DAY MODE
1. Press C to toggle between Time 1 and Time 2.
2. Hold C for two seconds to set Time 1 or 2 as default.
3. Press D to turn on/off key tone.
Time 1
> To set Time, press A until hour flashes. Press B to select the setting
item. Use C and D buttons to adjust the values up or down. Press A to
exit set mode.
Time 2
item. Use C and D buttons to adjust the values up or down. Press A to exit set mode.
> The range difference between Time 1 and Time 2 is 23 hours.
CHRONO MODE
1. Press C to start and stop chronograph.
2. Press D to Split/Reset the chronograph.
3. Press A to recall the memory if Chronograph is stopped.
4. Press A again to view the next lap.
5. Press C or D to exit Recall mode and go back to Chronograph mode.
6. There are a total of 10 lap memories.
TIMER MODE
1. There are 3 different modes of timer: Count Down-Stop, Count DownRepeat, Count Down-and Up.
2. Press C to start/stop the timer counting.
3. Press D to reset the counter to the preset value if timer is stopped.
4. Press and hold A for 2 seconds to enter Timer Setting Mode. 35 Timer Setting Mode
5. Press B to cycle around the setting item: timer-type, hour, minute,
second and to back timer-type again.
6. Press C and D to increase/decrease the setting value.
7. Press A to exit the setting mode.
TIMER ALARM
Timer alarm will beep 2 times a second for 30 seconds.
ALARM MODE
1. Press C to select the alarm.
2. Press D to enable/disable the alarm.
3. Press B to change to Time mode again.
ALARM SETTING MODE
1. Press and hold A for 2 seconds to enter the alarm settings mode.
2. Press C and D to increase or decrease the settings value.
3. Press A to exit the settings mode.
Nov 19, 2012 | Watches
How to set time on adidas adp6011 watch
1) Press "SET/LIGHT" (top-left) button for 4 seconds.
2) Press "MODE" (bottom-left) button to reach blinking hour/minutes (~4 times press)
3) Change whatever you want (Hour/ minutes/ seconds/ date)
4) Press "SET/LIGHT" (top-left) again to set whatever you changed.
ENJOY
May 27, 2012 | Adidas Watches
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
Adidas Mens RESPONSE ADP3017 Black Resin Quartz Watch with Black Dial Logo
Top Adidas Watches Experts
Ansel Alberto
Ansel Alberto
Watchmaker71
Level 1 Expert
Are you an Adidas Watch Expert? Answer questions, earn points and help others
