Question about Phoenix Manual Treadmill
Fix incline Health stream Dk380 won't decline on handset or dash can you help
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
Inclines down, declines up
The unit has likely been disassembled and put back together incorrectly. The incline/decline motor runs on direct current, and reversing the polarity of the terminals on this motor will cause this exact problem. If it has not ever been serviced, I would look on the manufactures website for a software update, or fix.
Apr 18, 2014 | Exercise & Fitness
Pftl788071 incline
Sounds like the button on the panel is stuck somehow, I think this because when you switch the wires this would reverse the polarity to the incline motor.
can you tell if the panel is recognizing the pushing of the incline buttons, like with a beep or light or something? If it didn't seem like it's responding this may be because one button is constantly stuck down.
Apr 14, 2014 | Proform Exercise & Fitness
Not incline or declining
I expect there is a limiter switch that tells the treadmill when it has reached its maximum elevation. The switch is probably either malfunctioning or broke.
Feb 27, 2014 | Nordic Track Exercise & Fitness
Pro-form 415LT. The incline/decline is at its highest incline and won't go back down. I did the troubleshooting correctly and still won't go down. Is there something else I can do?
LUBE the rack and gear very well. Adjust the POT small attached, and try again. However you must see the diagram attached Tight any wires and connector very well and clean .Will be a good idea RUN again the software calibratin after you did the adjustment, clean and lube.God bless youf6d33b22-202a-4b16-8ded-0ff86a59d4cf.jpg50d1e909-5210-4c2b-b9b8-58ceb55bc2ed.jpg
Apr 05, 2013 | Exercise & Fitness
When inclining/declining it make a terrible noise.
Vision Fitness should be able to help and may be able to supply a manual
Jan 25, 2013 | Vision Fitness T9200 Treadmill
The incline and decline not working
please RUN the software calibration for easy diagnose, troubleshooting and fix it.
God bless you
Sep 17, 2012 | RTO Exercise & Fitness
Please RUN the software calibration under the HOOD cover from the motor the instruction, for easy diagnose, troubleshooting, and fix it.
God bless you
Sep 17, 2012 | RTO Image 15.0R Treadmill Walking Belt
Treadmill keeps inclining and declining . It won't stop!
I have a Proform ZT5 model - had the same incline/decline problem. It needed calibrated.
- unplug, turn off, and take the key out
- plug machine in
- turn switch on
- Pres and hold the STOP and SPEED UP button at the same time, while holding them insert the RED KEY
- let go of both buttons
- press STOP 1 time
- pres INCLINE UP 1 time
- this should reset it.
The tech on the phone mentioned the importance of turning the maching off, taking the key out, and unplugging after each use. Leaving it plugged in there is still an electrical current running and this can cause more seriouc problems that require a new control panel.
May 08, 2011 | Proform ZT5 Treadmill
Phoenix Manual Treadmill Logo
22 people viewed this question
Top Phoenix Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Phoenix Exercise and Fitnes Expert? Answer questions, earn points and help others
