Question about Sanyo DS32224 TV
Digistar lc 20h3d - Sanyo DS32224 TV
I have a Digistar HD LCD TV model LC-4010D. I have no remote for the TV. When I turn it on, the blue light turns on to show that it has power. But no picture or sound appears. It is currently plugged into...
I'm not familiar with the tv set, however here are some things to try.
It's possible that the tv powers up in stand-by mode, so you'll need to find a way to turn it on completely. See if there are channel +/- buttons on the tv and try them.
If the remote might be necessary, try to see if you have friends/family with a universal remote control, such as a Logitech Harmony, to lend to you for testing. This way you can avoid spending money for nothing on a remote.
Googling on this brand and model gives a lot of negativity though: a lot of problems posting, but no support or even an online manual. Personally I've never heard of Digistar. It might've been a bad investment.
Oct 17, 2013 | Televison & Video
I need the code for my digistar tv
Hello
Four digit universal remote code for digistar are:-
1019 0165
.................................... 0118 0116 0167
Mar 15, 2011 | Televison & Video
Looking for a wiring schematic for a DIGISTAR tv, model # CR-20SS01D
You might try contacting Digistar Directly, here is the info:
Address : Digistar Group
B5/5/5, 4th Floor, One Ampang Business Avenue,
Jalan Ampang Utama,
68000 Ampang,
Selangor,
Malaysia. pixel_220x15_white.gif Telephone : +603 - 42534319 (Hunting Line) pixel_220x15_white.gif Fax : +603 - 42572168 pixel_220x15_white.gif Email : digista@digistar.com.my pixel_220x15_white.gif URL : http://www.digistar.com.my
Oct 14, 2010 | Televison & Video
Codes for Digistar TV
code for remote filips
Dec 26, 2009 | Televison & Video
Code for jensen universal control for digistar tv
manual fot jensen3000 remote or code search
Oct 03, 2009 | Jensen JR400 Remote Control
Codes for 20" Digistar model tk2055d tv remote
THE BEST SOLUTION IS THE SIMPLEST ONE.
I suffered for 1 month shopping around for an universal remote control that has a code for the Digistar tv brand. It was in vain.
So just turn to the simplest way ..the programming with code search (on the guide of the universal remote control- which has not the code for digistar brand) In the paper it tell you exactly what to do. I bought a 3 device universal remote control.
On mine it showed five easy steps to follow and the remote finds itself the code and programs it .You do not put any code ever, the remote just simply WORKS perfectly. I have solved this problem just 5 minutes ago..Oh ...I forget..On the universal remote control instruction it said that you might have to press the ON/OFF button up to 200 times , so i thought "I never tried this one, better then waist days and months will no solution. I nedded to do it only for 30 times or so beffore the TV turned OFF, and than I pressed the ok button on my remote (probably to save it- or who cares-as long as you follow the instructions). Then I could turn back on the Tv and P{LAy with the remote without putting any code as the remote it programmed for the Digiistar brand..I'm so HAPPY...Try it and spread the "new"...It is Ironic ..it was there all the time...we look in more complicated zones and do not see the solution sitting under our nose:((:)))
GOOD LUCK!
Oct 19, 2008 | Televison & Video
Digital tuner
Salutations AnnLeo,
The easiest way to respond to your questions is with a question of my own. Are you currently able to pick up any digital broadcasting from your local stations now, such as any HD broadcasts?
If your not then you may not have an built in digital tuner, but not to worry. It is true that if you subscribe to cable or satellite services they automatically covert your signal back to analog so the television can receive the programing. Otherwise I would suggest you look in to options for the digital tuner coupons. Information on the coupon program and other basic frequently asked questions can be found at:
http://www.bestbuy.com/site/olspage.jsp?id=pcmcat120600050013&type=category
I hope this helps.
Jon
Go Ahead. Use Us.
May 29, 2008 | Televison & Video
Sanyo DS32224 TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
