Question about Technics SL-DZ1200 Turntable
Audio skipping... Hi there. My unit seems to skip very slightly when the platted spins at one specific point. You can hear the audio stutter a bit whenever it spins to that point. Is the lazer completely pooched? Any insigh would be great!
Hi there, i'm not exactly sure if your laser is as you say "POOCHED" I also have an sl-dz1200 that seems to be doing the same thing as yours (skipping or slurring at one particular point) i don't believe that the laser would be "pooched" but the laser would definatly need cleaning. i also believe that the problem may lie somewhere with the direct drive motor for the platter and mechanics of the cd player itself (think caching in pc's) if your pc isnt set up right you music sounds skippy, slurry or even broken (please don't quote me on this problem because i'm not an expert) but i have also noticed that the problem still occurs at the same spots on my unit when the music has been paused and i manualy push the platter around to simulate the same motion of playback, I'm putting my unit in to be serviced in two weeks. If you like i could keep in contact with you and let you know what the problem ends up being my details are: NV-Entertainment@Hotmail.com regards dj-nam
Posted on Aug 14, 2007
Hi there, dj nam.. here is the follow up to my last post 14/08/07.. Re: response to pooched laser Ok this is what i have so far.. As so far, I have not needed to get my unit serviced, I did a little more research and found that the problem (pooched laser) is located in one of two places: (1)inside the player underneath the lcd you will see both a clear plastic ring (connected to the platter) as well as a sensor that the plastic rings edge runs through.. This is the sensor system that reads the platters spinning and scratching times and distances. It is more than likley that either the sensor or the plastic ring (or both) is dirty hence blocking the sensors light and creating the pooched sounds as you describe. both the ring and sensor will need to be cleaned (warning re: plastic ring.. absolute care must be taken when cleaning this ring as it will easily scatch and you will have to order another ring) i would recomend using. a very, very soft cloth and no cleaning agents. Or you can use an air canister/ air gun (2)Inside the actual platter itself are two plastic/ teflon like surfaces that slide back and forth over each other when you scratch and backspin the platter. (they are visible when you remove the silver spin disc and you turn/ slip the platter - look at the three holes in the top plate and you'll see them) Just like the first solution these surfaces are more than likley to be dirty and also need to be cleaned. It is a bit harder to get all the way into the guts of the player to remove the platter to get to theses surfaces, but if needed i could e-mail you instructions on how to do it. I have picked up a few little tips n tricks in the past two weeks that also could sort the problem out (some you would be amazed with - i was), that is if the problem continues after you try the "first" tip out. I can be contacted via e-mail on NV-Entertainment@Hotmail.com regards dj-nam
Posted on Sep 07, 2007
Denon dcd 425 cd player:the tracking mechanism keeps SKIPPING but it SKIPS BACK like the counter will read @ 20 and the next thing you know it has skipped to 14 ??
Hopefully it's just a bit of dust on the lens. Or something inside the unit that is obstructing the mechanism, such as dirt.
Oct 01, 2017 | Denon Audio Players & Recorders
Record skipping despite new needle
It could be something to do with the turnatable's platter. Is the matt that the record sits on faulty. Does the platter wobble up and down with no record on it? If you can see this happening you might need to check the platter out. If it's a belt driven the belt can come out of position causing such problems. Also objects can get stuck inside the platter. Especially if you have small children in the house!!!
Feb 28, 2013 | Crosley Cr704 Audio Shelf System
Describe your RCA Audio Shelf System Problem
If you have cleaned the CD lens using a cotton swab and alcohol and it continues to skip, try cleaning the rails that the optics assembly rides on using a clean cotton swab. Sometimes the grease on the rail gets contaminated with dust and that causes the optics assembly to stick a bit. The motor that moves the optics assembly will generate more torque and when the optics finally move, they overshoot the target position. This results in a loss of information that you hear as a skip.
If neither suggestion works, please update this and we'll try another option.
Thanks,
Dan
Dec 30, 2009 | RCA Audio Players & Recorders
Picture Stutters on HD Channels
Hi my name is Roety,
I can help you with your issue ,
 Sounds like a bad signal issue , check it on other inputs to confirm
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 20, 2009 | Vizio GV52LF 52 in. LCD TV
DVD player skips audio and/or frames
PowerBook G4 is at least a five-year-old machine at this point. A DVD drive can **** in lots of dust in five years. Try hooking up to an external DVD drive. If it plays the same discs with no problem, you need a cleaning or replacement. Frankly, an external DVD drive is cheaper than replacing your internal drive.
Mar 07, 2009 | Apple PowerBook G4 Mac Notebook
Skips and clicks
Still having this problem? Mine was doing the same thing, so I went on the Presonus website and updated to the latest drivers. Mine hasn't done it since. If you have done that as well and it is still doing it, then I fear my problem may come back too. Hope not.
Jeff
Sep 28, 2008 | PreSonus 6x10 Firewire Recording Interf...
RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Feb 10, 2008 | RCA 100-Watt Stereo System With 5-CD...
Recording audio on hard drive for books, etc.
Probably too high a setting in record for your computer. Try setting the quality down a little and see if it helps.
Nov 19, 2007 | Creative Labs Sound Blaster Live! 5.1...
Technics SL-DZ1200 Turntable Logo
194 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
