Question about Radio Communications
Micronta cat no 21 522 swr tester - Radio Communications
2 Suggested Answers
SOURCE: micronta field strength/swr tester cat. no. 21-525b
I hope it will be useful
Posted on Sep 08, 2008
How does a person adjust the swr with the built in swr calibrator
You can't adjust the SWR with the built in calibrator. The radio has a built in SWR tester but does not have an antenna tuner.
Ideally you should tune or repair the antenna.
Secondly where that is not practical, there are antenna tuners available for sale. Find and buy one and it should correct your C/L imbalances or impedance problems.
Feb 18, 2016 | Radio Communications
How could I find a manual?
They are fairly straight forward to use. The dial is for selecting what you are metering. AC or DC voltage and range. Resistance. Amps. The probes may need to be plugged in differently depending on the meter function.
Sep 07, 2014 | radioshack MICRONTA 3 WAY HF SWR METER...
Need manual for Radio Shack MICRONTA 63-3003 VLF Metal Detector
Go to http://www.scribd.com/doc/38611721/63-3003-Micronta-VLF-Metal-Detector-Manual
Sep 23, 2012 | Vehicle Parts & Accessories
Versitile
It should, most any Strength/Signal Wave Ratio tester works with most any radio. But then again, Marine radios are always trustworthy, a study shows that they are the best form of emergency communication. Why would you need to test it?
Aug 02, 2008 | Radio Communications
Instructions for a swr meter/cb radio
An SWR meter is used to see how well your antenna is matched to your transmitter output, just like using the correct speakers with an amplifier.
There are usually two readings. FORWARD and REFLECT
or FWD and REFL
Firstly, make sure the antenna selector is in the correct position and set for the antenna you are using.
Next, switch your meter to FWD (FORWARD). Switch your transmitter to low power and press the microphone key.
Next, adjust the CAL knob for the maximum power reading, but not so far that the meter exceeds maximum!
Keep the microphone key pressed and switch to REFL (REFLECT). If your antenna is matched, the meter should now give a low reading. If the reading is very high, you must match your antenna by making adjustments or by using a matching unit.
A poor match will mean a poor signal. A very poor match can damage your transmitter and cause interference.
When you have a good FORWARD reading and a low REFLECT reading, your system will be reasonably matched and you can then use higher power. Remember that you will need to reduce the CAL knob to a lower setting when running high power.
Mar 05, 2008 | Computers & Internet
SWR Meter
No problem, Follow the link http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=21-525&Name=CB%20Accessories&Reuse=N It's off to the right under other documents. Good Luck and hope this helps L8R
Sep 17, 2007 | Panasonic CR-SRF100 SIRIUS Radio Receiver
Radio Communications Logo
145 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
