Question about LG LDC22720ST Stainless Steel Bottom Freezer French Door Refrigerator
How do i get the drain pan out to clean it - LG LDC22720ST Stainless Steel Bottom Freezer French Door Refrigerator
LG ptac MODEL : LP153HD3A collecting condensation water in bottom but not going to outside drain pan.
there is probably a blocked pipe or filter it will need cleaning, you may need a pump to remove the water first to get to the pipe to clean it out.
Jun 19, 2017 | LG Heating & Cooling
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Jan 19, 2015 | Samsung RF4287HA 28 cu. ft. French Door...
How do I clean the drain pan? Why in the world would anyone make a fridge that has a non-removable - and even a non-accessible drain pan? It stinks after awhile and it does need cleaned - even if jus
The "cover" is removable. Once the cover is removed, you can gain access to the pan and remove it for cleaning. The removal process can be a little tricky, but it can be done.
Dec 19, 2014 | Refrigerators
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Bad transmission seal on a 2002 ford explorer
Drain the Transmission Fluid and Replace the Filter
Raise the car with ramps or a floor jack and support it with jack stands. Find the lower cover of the torque converter housing. Turn the torque converter until you find the drain plug. Place a drain pan beneath the drain hole, remove the plug and drain the fluid.
Remove the cooler lines at the transmission and flush them with compressed, low pressure air. Be careful during this step; fluid may shoot from the other cooler line.
Place a large drain pan beneath the transmission. Loosen the retaining bolts on the oil pan with a socket wrench until they are within a few turns of removal. If the seal doesn't break on its own, gently tap it with a rubber hammer. Fluid will drain from the edges of the pan.
Remove the pan retaining bolts when the fluid stops draining. There is still transmission fluid in the pan. Hold the pan carefully and drain as much as you can into the drain pan.
Scape the old gasket material from the mating surfaces on the oil pan and the transmission. Discard the old gasket. Clean the magnet in the pan. Clean the pan and the mating surfaces with a solvent and a clean, lint-free cloth. Replace the magnet and allow the pan to air dry.
Employ a socket wrench to remove the bolt that holds the filter onto the transmission. Some models may have two bolts. Pull the filter and any old seals or gaskets from the transmission. Install a new filter assembly, including any required seals or gaskets.
Put a new gasket on the oil pan and reinstall it on the transmission. Tighten the retaining bolts to 79- to 119-inch pounds with a torque wrench. Replace the cooler lines on the transmission and the drain plug on the torque converter.
OBD Tools 365 Days Shop
Sep 25, 2014 | 2002 Ford Explorer
How to clean the drain pan
You can access the drain pan thru the back panel on most whirlpool refrigerators. Most drain pans are diffucult to remove so clean the pan without removing it. Be sure to put a little bleach in the bottom of the pan so no mold will grow.
http://www.on-timeappliance.com/refrigeratorrepair.html
Mar 28, 2012 | Whirlpool Refrigerators
Need to change the transmission filter
get your self the right tools, the filter, transmission fluid, gasket, gasket silicon, a good wide drain pan, clean rags, some cleaner to clean out the pan like brake parts cleaner. first find the transmission pan. once located undo the bolts around the pans flange or use the drain plug to drain all the fluid. if it doesnt have a drain plug then you have to take off the pan to drain it, messy! once the pan is off you should be able to see the filter and swap it out. clean out the pan, pan magnent, put your new gasket on and use some silicon, bolt it back on. fill the trans back with new fluid. this is straight forward approach. and dont mix the oil pan with the trans pan. the oil pan is under the motor( if that helps) let me know if you need any help or you dont understand something, thanks
Nov 07, 2009 | 1998 Honda Accord
Air Handler leaking
First make sure unit is level. Drain pan may be dirty. On the rheem or Ruud unit the back of the pan gets stopped up. Ithas small holes that let the water by and they get stopped up. Now even though your drain is clean you may have a stopped up dain pan. Check this > These are problems you can take care of your self. Open up the top panel of your unit and you can look down on the drain pan. Check for dirt and stoppage near the outlet of the drain pan. You amy also have a cracked drain pan but I doubt it. Rus
Jul 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
2003 Dodge Stratus
no drain plug, no car or truck has had a drain plug for decades, reason? they want the filter changed with the fluid, so they make you pull the trans pan to drain the fluid, one very messy job.
Feb 12, 2009 | 2003 Dodge Stratus
Drain pan
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
Oct 24, 2008 | Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top...
LG LDC22720ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
60 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
