Question about Garden
Weedeater model # XT 20 T carb adjustment and plug gap
2 Suggested Answers
  • 125 Answers
SOURCE: what is the plug gap on a craftsman weedeater model 358.795050?
.022 inch
Posted on May 02, 2009
Spark plug gap on a stihl leaf blower shoulder strap
.0020 is the gap.Here's a link to your manual,it's listed in section 26,specifications. http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/STIHL-BG-56-66-86-SH-56-86-Owners-Instruction-Manual.pdf I also had a B56C and after 2 years,the engine locked up,am very disappointed in these ,also have a weedeater that the carb had to be rebuilt twice,if you leave gas in them over the winter,it messes up the carb,we'll I threw the blower away,got a huskvana from lowes,it is awesome,Stihl has let me down,will never buy another one,guess your having problems now,want to buy my weedeater and 500 chain saw.lol.
Aug 08, 2015 | Stihl Garden
I have a Ryobi RY28120 gas powered weedeater that will start sometimes and not at others. Not sure if the carb needs cleaning or if it need a new muffler. Maybe adjusting carb screws? Not sure! Also,...
Use only fresh gasoline (alcohol free if you can find it). Purchase a top quality synthetic 2 stroke oil such as Lucas, Golden Spectra and mix it exactly as the manufacture dictates. Install a new accurately gapped plug and make sure the plug wire cap (boot) is pulled back to inspect the wire to connector crimp. Start it up as you normally would to allow the new gas and oil to permiate the system and if you cannot get it to stay running without the choke being on shut it down and squirt some oil into the carburetor and pull the trimmer over, if this makes it start everytime it does not want to start and it allows you to click off of run you have either low compression (rings are worn). or your carb is yet another victim of the geniouses that thought alcohol in gas was a super idea. Either way you can replace the piston and rings or the carb. both are almost not worth the time and cost anymore, a new carb for mine is $70.00, with a new piston and ring set being around $40.00 and a brand new trimmer the same as this one on sale at $130.00 it was an easy decision to buy new.
Jul 18, 2014 | Ryobi Garden
My Yamaha Raptor 660 is back firing and not reving up
could be a few things your fuel filter could be clogged along with your air filters your crabs may be gummed up did you make any adjustments to your carbs 3 turns on lh carb 2 turns out on rh carb i like using sea foam it seems to keep my fuel system clean try that stuff i also gap my spark plug at .033
Jun 10, 2014 | 2004 Yamaha XT 660 R
Ran well the 1st yr. Added Stabil - would not start this yr. Have put fresh gas in but will not start.
you added stabil but did you run the gas out of the carb? Take the carb apart and klean all with carb cleaner, spray in all holes. Check the plug gap of the new plug while your into the unit anyway the gap should only be 1mm.
Dennis
Nov 06, 2012 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Can't find owners manual for the following weed eater model numbers xt-200, xt-260 and poulan model # p35oo
XT200: http://www.weedeater.com/ddoc/WEEO/WEEO2004_USen/WEEO2004_USen__530163333.pdf
XT260: http://www.weedeater.com/ddoc/WEEO/WEEO2010_USen/WEEO2010_USen__545186831.pdf
P3500: http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2007/NOUS2007_545154718.pdf
Sep 06, 2011 | Garden
Weedeater BV200 will not crank. I have put in a new plug and a new Ignition Module (gap at .008). It is getting spark and appears to be getting fuel. The compression is at about 85 after 3 pulls. Any...
if your getting spark, then most likely its bad gas, or carb needs adjusting. i would rebuild the carb 1st, then adjust. if it has old gas in it, quite possible its gunked up. if no help there, take muffler apart and check screen. these go bad quite often. and always make sure air filter is atleast clean, or replace it every season. most neglected, and so so important. if a machine cant breath, it cant preform!
Sep 22, 2010 | Poulan Garden
Weedeater hedge trimmer will not stay running.
Firstly, make sure that the fuel mixture is good, as old or incorrectly mixed fuel, is a possibility.
Then as long as the air filter, and spark plug are ok, check that fuel is entering the carb. If so, you can adjust the timing, by expanding or reducing the gap between contact, and the magneto/coil.
You can also adjust the timing, by changing the gap on the plug too.
There ya go,
FixedYa!
Don't forget to rate, thanks ;)
Aug 01, 2009 | Garden
Weedeater xt-85t fuel leak
the float in the carb is stuck un screw the nut on the bottom of the carb take it off t6hen put it back on that should do it in the mean time leave that thing out side
May 06, 2009 | Garden
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
