Question about Xerox FUJI DOCUPRINT CM205 B COLOR MULTIFUNCTION LASER PRINTER
024-340 after restart still cannot use
Reiniciar el equipo
Normal restart: select restart from the apple menu, or press the power key (the sleep/restart/shutdown dialog appears), then click the restart button or press the "r" key.
Forced restart (use only if the computer crashes or freezes): Press simultaneously the Apple, Control and power keys.
Forced shutdown (use only if the computer won't respond to anything, not even a forced restart): Press and hold the power button on the computer until the computer shuts off.
Jul 02, 2013 | Apple iMac Computers & Internet
Nokia e52 restart problem
in what way do you have problem with restart?
did you make restart to default configuration? or just restart?
one way is to take battery out, wait for a short while, then reinsert and restart - if that does not help, then I suggest trying to reset it to default settings -- if phone does not restart at all, then try with another battery - if still not restarting, then try with another simcard - and if STILL not restarting, try bying another phone :-)
Feb 13, 2013 | Nokia E52 Smartphone
Restart
Automatic Restart? Are you trying to Start Automatic Restart or Stop Automatic Restart?
If you have having boot problems and the system keeps restarting, then turn off the computer, then hit the power button and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down past Safe Mode and you will see an option to DISABLE AUTOMATIC RESTART. Take the Disable Automatic Restart option.
Mar 28, 2012 | Computers & Internet
Every time that i install 1 drivers to my laptop, do i have to do a restart?
I've it asks for it, you " could " restart.
Normally the driver will work without a restart, but i've it wont work restart your computer.
Jun 11, 2011 | Dell Computers & Internet
My HTC Diamond restart and restart and restart....
It might be something you have installed. I think the fastest way to get rid of such a situation is to perform a hard reset. You must know that you'll loose all your personal data, and how to do a hard reset, but here I go, anyway. There two ways to hard reset your Diamond.
Software way: Go to 'Start > Settings > System tab > Memory > Clear Storage tab', enter password '1234' and tap OK.
Hardware way: Turn your device off. Then, press and hold the ENTER key. Whilst keeping this key pressed, briefly press the POWER button. Release the ENTER key when a waring screen comes up. Then, press the VOLUME UP button to hard reset your device, or any other key to cancel the hard reset procedure.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 12, 2010 | HTC Touch Diamond Smartphone
How do i restart my laptop
There are many ways to restart your laptop.
  1. The most common things to restart is to click start button and click restart.
  2. Another way to restart is to press the restart button of your laptop.
  3. You can also long press the power button until the laptop will shut down and turn on your laptop again.
Mar 26, 2010 | Tablets & eReaders
Help my hp dv2000 just keeps restarting??
As the computer is working in safe mode, it is clear that operating system files are corrupt.
Perform a repair installation, if it is Windows XP.
For Vista or Windows 7, you can perform system restore from recovery console. To launch recovery console, insert the disc- restart the computer and boot into the disc. Choose repair in the options tab, then choose system restore from the list.
Regards,
Nags
Jan 27, 2010 | HP Computers & Internet
My samsung sgh-f500 always restart upon opening my cell then continous restarting what will i do
my samsung sgh-f500 always restart upon opening my cell then continous restarting & keypad not working at this time what will i do
Jan 08, 2010 | Samsung SGH-F500 Cellular Phone
My web cam built in dont work
You need to uninstall previos web cam driver/s from (control panel>add/remove>uninstall web cam drivers), restart the system and then install suyin driver
I hope this helps!
Aug 01, 2009 | Acer eMachines 520-2890 Notebook
Xerox FUJI DOCUPRINT CM205 B COLOR MULTIFUNCTION LASER PRINTER Logo
47 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
