Question about Razor Dirt Quad Bike
Razor control module
I turn the throttle and it won't move. The lights go from red green red yellow. If you turn the switch off and turn back on then it goes back to red green on throttle but no power.after installing new batteries.
3 Suggested Answers
  • 636 Answers
SOURCE: I have similar problems with my razor mx350.
sounds like the CDI box is shot. This should be located either under the seat or the left rear side of the fuel tank if memory serve me correct.Fairly cheap part 20- 25 bucks.
Posted on Jul 24, 2009
SOURCE: Problem w/ razor dirt quad.
Well this post was done a long time ago, seems like you have a bad battery. you should see 24vdc. The batteries are in parallel so it adds up to 24 volts.If one of them is dead it would only show 12vdc.
Posted on Jan 17, 2011
It makes clicking noise when you use the throttle
Thats the controller relay clicking....if it won't move disconnect the brake switch connectors from the controller and try again. Make sure the batteries are fully charged and in good condition. There should be at least 12.6v or more on each of them with no load. The green light on the throttle should be on when you turn the switch on. If it goes to yellow and/or red when you give it throttle, your batteries are probably weak. Then connect the battery wires directly to the motor and see if it works. If the motor operates and it wont go you need a freewheel. If none of this helps try shorting the power switch wires with your screwdriver or a piece of wire. Sometimes the contacts have too much resistance.
Feb 03, 2013 | Razor MX500 Dirt Rocket
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1996 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1996
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: Retain Keyless entry with secondary Harness Listed Below
Additional Accessories:
Metra Brand Dash Kit: 89-30-7891 - 99-7891 - 99-7898
Metra Brand Wiring Harness: 70-1720 W/Keyless Entry # 70-1720T
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Ignition 2: Yellow - Ignition Switch Harness
Accessory: White/Black - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Blue/Black - (-) Driver's Kick Panel
Parking Lights: Red/Black - (+) Driver's Kick Panel
Head Lamp: Red/White (L) Red/Blue (R) - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Above Fuse Panel
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Orange - (-) Module Behind Radio
Horn: Grey - Steering Column or GREEN connector behind radio
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : Blue/White - Driver's Side Dash Footwell, Grey connector.
NOTES: PPM - 4000PPM
ROSTRA Control Arm # 250-3421/250-1483
ROSTRA Throttle Adapter #250-4249
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
How will i know if its my batt or motor on off switch lites up red but nothing happens
Lift the rear wheel up off the ground and apply the throttle, while watching the throttle lights. If the throttle light goes from green to yellow or red it shows that the battery voltage is dropping under a light load because the batteries are low in capcity - not holding much charge. Most battery places will load test the batteries free of charge to confirm this.
Have a look at the trouble shooting guide here
http://www.razorama.com/razor-installation-guides.html
and the wiring diagram here
http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jul 30, 2012 | Razor MX350 DIRT ROCKET - BLUE
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
When then batteries are charged, i turn on the switch and the red and green light are on, then i pull the throttle and the yellow light flashes once. whats might be wrong?
The battery voltage is dropping under load, as indicated by the throttle light changing from green to yellow. Likely you batteries need replacing. most battery shops will test them for free to confirm they need replacing.
battery replacment guide and other trouble shooting information is avilable here
Jun 28, 2012 | Razor MX350 DIRT ROCKET - BLUE
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F65 Mini Not used.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F76 Mini Not used.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
Jan 07, 2011 | 2003 Jaguar X-Type
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Razor Dirt Quad Bike Logo
121 people viewed this question
Top Razor Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
Betty L Kidd
Betty L Kidd
ray gallant
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
