Question about Kitchen Appliances - Others
Trash Compactor Thumps
We turn the compactor on, it goes through the cycle then when it would normally stop it starts thumping and won't turn off.
    Master:
  • 563 Answers
I would guess there is a limit switch that tells the machine to stop once the compactor has retracted.
Posted on May 04, 2013
  • 1 more comment
  • bonniemerric May 04, 2013
    Probably, but how do we fix it?
  • Chris Weiser
    Chris Weiser May 04, 2013
    I would say you will need to get above the ram or remove the unit to access this. You can try fooling the compactor to make it think the can is closed then engage the ram to bring it down so you can see behind it (obviously take care and be cautious). Or remove the unit and open it up. Depending on what method they use to determine on/off points will determine what you will need to do to fix it. It could be as simple as a switch that the ram head will contact when it retracts fully, or it could use a cam drive system which may just need adjustment. I would guess they would keep it cheap and just go with the switch.
  • LARRY ROBERTS
    LARRY ROBERTS Jan 02, 2014
    how can the unit be removed. i can not find the retainers
SOURCE: trash compactor problem
I have had this problem on my GE Monogram. The 'smasher' is near the bottom and does not move anymore, even though the motor is working.
What I did was to get a crowbar that would fit through the crack and hook the underneath side of the bottom plate. You also have to hold the switch so the motor runs with the door open and pull up on the plate until the drawer can be slide out. The trunnion nut (a plastic nut) was cracked. I replaced it 3 years ago, and it just cracked again. They now make it out of metal, so maybe it will last longer. Ordered it from appliancepartspros.com.
Posted on Apr 26, 2008
SOURCE: GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Posted on Dec 25, 2008
SOURCE: My KitchenAid trash compactor model KUCP021RBL1: cycle does't end
Most likely the motorwindings have been overheated after staying to long time in down position and trying to get up.
If there is a Emerson motor in your compactor than you will not find anything wrong most likely it is the winding of the motor, we have had this two times, changed the motor and the problem is solved.
Kind regards,
Paul
Netherlands
Posted on Mar 04, 2009
SOURCE: Trash Compactor will not start
key stays on but won't continue running, starts to run and then quite
Posted on Aug 11, 2009
erpaalai
  • 999 Answers
SOURCE: GE trash compactor ZCG3100BVV-02 won't start.
Most likely a ram position switch but could also be a bad motor. process of elimination will lead to the faulty component...Eric
Posted on Sep 12, 2009
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
My plate compactor won't start, what could be the problem?
are you using the choke? do you have the throttle on at least a little bit? if these things are ok, you probably need to add oil to the engine
Jan 16, 2013 | Tools & Hardware - Others
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
Whirlpool trash masher locked and motor won't stop running
turn off electric breaker, check limit switch for proper contact/operation
Oct 03, 2011 | Whirlpool 800 Series Undercounter Trash...
I want to install a vinotemp Model: VT-TC32SB. Currently, there is a trash compactor in the space. If I pull the trash compactor out, can I just slide the fridge in place? The countertop and cabinets are...
Hi, It depends a little bit on how your trash compactor and cabinetry are currently set up. Some people have a tough time getting the trash compactor out/cooler in because of the lip that comes down off their counter. However, if you can pull one out, you "should" be able to just slide the other one in. Likewise, you'll need to be sure there is an electrical outlet available in the space. Usually, this isn't a problem as your new Vinotemp will plug right in where the trash compactor was plugged in. But in very old houses sometimes the trash compactor was wired right into the electrical. As long as your counter/cabinets were designed with enough room to move units in/out, this change should go smoothly for you. Best of luck!
Aug 30, 2011 | Refrigerators
I need to know how to get to the blend door in the heater area of my '92 chevy c1500. I was told that is what makes a thumping noise when the key is on or off.
this is some what normal, as long as it just once that you hear the noise (ie. you turn the truck on and thump, turn the truck of and thump) the doors operate off of vacuum lines in the engine. When you shut the engine off the vacuum goes away and *thump* the blend door snaps back to its normal resting position. then when you turn the truck on the vacuum then comes back and *thump* the door snaps back to its adjusted place.
If you feel that this is not what is going on, this diagnostic technique can help eliminate this condition
set the blend door to the hot side and start the truck and it should thump when the engine is on or off.
if you didn't get a thumping noise that is good it just means that the blend door is set to the hot side normally open.
Apr 18, 2011 | 1999 Chevrolet Silverado 1500
My ge profile 15" compactor stopped compacting. I
The "wheel" has a cracked center that you can not see unless you take the whole gear off.( I am assuming the "wheel" is off the motor and should be driving the chain that goes to the side gears ) There is a tension washer looking thing that holds it on and you can force it off with a flat screwdriver. Once off, I'm sure you'll see the center of the gear( hex shaped) is not engaging the hex gear shaft for being broken somewhere. An appliance repair store should have that part for less than $50. Sure beats the $85 the service people start with for just a service call.
Dec 11, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Kitchen Appliances - Others Logo
487 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
