Question about Gateway MT3705 Notebook
Compressor not running during cool mode-koppel 3.0tr.ceiling cassetee
  • Gateway Master
  • 7,627 Answers
Wrong category
Posted on May 04, 2013
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
Apr 12, 2016 | Samsung Refrigerators
Compressor stops running.
in dehumidifier modes work like in cool mode..try in cool mode too see if it work
Nov 30, 2013 | Haier CPN14XC9 Air Conditioner
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
Koppel aircon
Wrong Category, try the AC category for a AC expert
May 04, 2013 | Gateway MT3705 Notebook
What does malfunction code E6 mean in a koppel super inverter airconditioner
WHAT IS THE MEANING OF E4 code in koppel inverter split type
May 01, 2012 | Heating & Cooling
What exactly does max a/c and norm a/c do; the difference, and performance? What does recirc do and why is it available during max, norm, and bilev but not during defrost? The same a/c properties are...
Hello: Max cooling is when the recirculate door opens. With the recirculate door open, 80% of the air flow comes from inside of the car and 20% is outside air. That makes the cooling more efficient. Normal a/c operation is 100% of airflow comes from the outside. These settings have nothing to do with compressor operation. Also Decreasing or increasing the amount of cooling has nothing to do with compressor operation, what that does is control the amount of air going from the evaporator core either through or past the heater core. The a/c compressor runs the same amount of time regardless of settings on the control panel. Also in cool weather the compressor runs in the defrost mode to keep the windows from fogging up. None of these settings affect performance, the only time performance is affected is wide open throttle (WOT) in that mode the engine computer shuts off the compressor to allow max power of the engine, ie: passing gear.. When A/C is selected the compressor is on, none of the settings will affect gas mileage, ie, low/high, max/normal 60 degree or 90 degree.
Jul 22, 2011 | 1997 Buick LeSabre
AC won't start. Fan runs
Depending on make & model, usually if you hear a "click" at control box at ceiling when switched to cool, that's a good indication of a faulty relay, capacitor , or maybe even compressor. Not something to play with if not experienced, especially capacitor. Have someone who knows electrical troubleshooting check voltages at compressor and you should be able to back-track from there and isolate problem. If no clicking at ceiling when asking for cool, check thermostat, then control box connections etc at ceiling. Need more info such as make and model number as well as thermostat type if more questions please.
Apr 27, 2010 | Dometic Rooftop RV Air Conditioner
Stops blowing air
remove cover at ceiling so you can see in at fins and see if they are frosting up bad. If they are, I suspect during AC installation, they didn't open up ducts on discharge properly and air flow is restricted, which will cause freeze up, especially if low flow from discharge ducts. I'm assuming it is a ducted system. You may have to remove or drop down entire ceiling assy, to see if the ducts into ceiling have any blockage. Sometimes they don't cut rubber roof material back far enough, or misaligned ducts and cause restricted flow to ceiling vents, which will cause unit to frost up, which kicks out compressor until frost is melted, then compressor kicks back in and cooling happens again.
Apr 06, 2010 | Dometic Rooftop RV Air Conditioner
Motor not running Refrigerator not cooling
There are three possibilities why the compressor motor is not running. #1. The thermostat switch is not closing to turn the motor on. #2. The compressor motor is bad. #3 The defrost timer is engaged, preventing the compressor motor from starting.
Solution for #1: Locate the thermostat switch behind the console in the refrigerator. It is attached to the freezer temperature adjusting knob. If you jump the switch out, the compressor motor should start. If it does, replace this switch.
Solution for #2: get another refrigerator. It is not worth repairing.
Solution for #3: Turn the freezer temperature switch to the coldest setting. Locate the defrost timer in the console on the ceiling of the refrigerator compartment. Look for position labels like "cool control" and "compressor". Jump between these two wires. The compressor should start. If it does, replace this module.
Mar 06, 2010 | Kenmore Refrigerators
Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
Nov 17, 2009 | Beverage-Air MT27 Beverage Cooler...
Gateway MT3705 Notebook Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
