Question about Crest Audio CC5500 Amplifier
Need a power transformer from 220v input to 120v output
I recently bought a CREST CC5500 amplifier and I realized it is only 120v , 20a-60hz. I need to run it with 220v, what can I do to make the amplifier go from 120v to 220v?? Can I internally change or switch something? Or I need a power transformer from 220v to 120v?, if sow, how many watts does the transformer has to have? wich one should y buy? 8 Ohm Stereo - 1150 W 4 Ohm Stereo - 1800 W 2 Ohm Stereo - 2750 W 4 Ohm Bridged - 5500 W
  • 1,934 Answers
Yes, you need a step down transformer. These are often rated in watts (the power rating is the same on both sides of a transformer) so it is easy enough to match this with the power consumption of the stereo. Apparently you will need about a 4kW transformer eg
http://www.220converters.com/store/p/45-Simran-THG4000-4000-W-Watts-Step-Down-Voltage-Converter-220v-to-110v-Transformer.html
Ugly things.
Posted on Jun 23, 2017
5 Suggested Answers
  • 4234 Answers
SOURCE: no power
These amps are very compact and are not the easiest to work on. If you are not experienced at repair, I would not recommend you start here. Where are you located?
Dan
Posted on Jan 14, 2009
  • 117 Answers
SOURCE: I have a Crest 3501S Amplifier. One channel is
The pre amp. inside the amp. is burned. A local shop can most likely fix it for about 100.00.
Posted on Dec 19, 2009
caroldon
  • 17130 Answers
SOURCE: how to activate 70v line of crest audio cki 800v
First of all the 70 volt line is used when we are dragging long lengths of speaker wires. hence to counter the drop we use a high voltage line brring it further down without any remarkable drop and use a step down matching transformer to power the speaker according to the impedance of the speaker to the secondary of the transformer. Connect the 70 volt to the 70 volt output in the amplifier. Now connect the other end of the wires tto the primary of the 70 volt transformer. Use the secondary output to connect to the speaker using the tap most suitable..2, 4,6,8 ohms . Check the phasing when you connect or reverse if the bass quality is less.
Hope this helps. Good day
Posted on Jul 19, 2010
  • 5370 Answers
SOURCE: when i turn on my crest audio 8001 it stay in
The power transformer is getting short and overheated causing it to go in thermal protection mode.Also if the amplifier gets overladed by its connection, it goes to thermal mode.
The problems i have seen most often in Crest amplifiers is bad capacitors. They look fine from the outside but pull one out of circuit and measure it and there bad. These are the small electrolytic types. there are 2 sets of solid white wires from each output module to the output relays. Inject a a signal into the amp and take a look at the signal on those white wires. If the signal looks clean with minimal DC offset then you have bad caps causing it to stay in thermal protect. A very common crest amplifier problem.
Check in between the heatsink's. These amps have a tendency for those heatsinks to arc across the sinks. There are only 2 thin rails that hold the modules and rough tour duty service can cause those rails to bend and the sinks to touch and arc. Even a bug getting between the sinks can cause them to arc if the amp is running hard!
Also look for open resistors. This are possibilities, that can cause the amplifier to remain in thermal protect mode.
------------- This should help.Thanks.Helpmech.
Posted on May 31, 2011
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Need a power transformer from 220input to 120output
What you need is simply a power converter device that knocks the power down for your device. Look for a UK (European) to USA power convertor on somewhere like Amazon.
May 04, 2013 | Bose Lifestyle SA-3 2-Channel Amplifier
I recently bought a U.S. version Nakamichi 600 II cassette console (120V), and I accidently burnt its transformer out by a 220V mains supply. Now I need to replace this burnt out transformer better with a...
To match it with an other transformer, you have to know about its secondary voltages. Try to download its service manual by internet. It will have all details. It will be best to contact any expereienced service technician or to the authorized service center for Nakamichi.
Feb 24, 2013 | Televison & Video
Can a Panasonic DMP-BDT310 Blue-Ray player from the US be set to 220V? Does it have a voltage selector?
No it does not have a voltage selector.
These units are made specifically for different regions A B or C.
I suppose you could get a converter.. 120v 60 hz to 220 V 55 hz.. but I would want to make sure it would play the proper format for your region before going through the trouble.
Best of luck
Apr 12, 2011 | Panasonic Televison & Video
Here in Australia we have different power sockets and power supply As I understand the machine I have has 120V 60HZ 1025 W What do I need to use it here in Australia? Do I need a new plug or a...
good day.
first,the power socket,,try to see the power plug of your machine and the power socket you have..compare it..when its compatible no need to replace,,if not you need a socket adapter.or if not available buy a new plug (if your plug is not compatible to the socket)
secondly,you don't need a transformer if your ac supply in Australia is 120v..
if the supply in your place bigger than 120v...like 220v,230 or 250v..you have to use a step-down transformer with input of what you have in Australia and the output is 120v..and of course pay attention for the wattage of transformer to avoid over heat or burn..I suggest to buy 1500w...
thank you and good luck
Apr 07, 2011 | Microwave Ovens
How to activate 70v line of crest audio cki 800v
Jun 29, 2010 | Crest Audio CKi 800v Amplifier
Converting 120v AC adapter to 220v AC adapter
I live in the Philippines, but I've got relatives in the US who send me gadgets as gifts. I've had the same problem with my laptop before but when I called HP call center, they said that as long as it says there input 100 - 240V, then it's ok to plug it in a 110 or 220 socket. Here in the PH, we have 220V sockets, but Americans use 110.
Anyway, your phone says it can only be plugged to a 120V socket (max) so that means, you have to use a transformer (that's what we call it here. a black box-like thing) to convert the volts from 220 to 110. If you plug your phone directly, it might explode.
I hope i answered your problem.
Nov 27, 2008 | Lands Phones
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
Crest Audio CC5500 Amplifier Logo
85 people viewed this question
Top Crest Audio Audio Players & Recorders Experts
spacil
spacil
Level 1 Expert
Chickenwatt
Level 1 Expert
Are you a Crest Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
