Question about Hoover Vacuums
Hoover hygiene plus vc358n
Motor overheating and cutting out
2 Suggested Answers
jmeredith
  • 417 Answers
SOURCE: Hoover hygiene full bag light
hi,
theres other filters that may be dirty and need to be washed or replaced below or around the bag, study the owners manual for alternate filter locations, basically the machine isnt getting the airflow it needs and is letting you know. The hepa filter is the most expensive, try and run the vac without it and see if the light goes out. Its okay to run it without but I suggest vacumming then dusting, not the other way around..
replace it as soon as possible
J
Posted on Jul 11, 2008
Panasonic Hoover cleaner motor cuts out and fuse blows
Using too much current. check to make sure that the motor is spinning at the correct speed. If there is grease caked on bearings it might be spinning slow, overheating, using too much juice and shutting down.
If motor speed is up to par and condition persists you may have some burnt/shorted windings responsible for the issue - the motor has to be replaced.
Dec 23, 2016 | Hoover Vacuums
I have a Vax turbo force 2000w hoover and it doesnt pick up theres hardly any suction and then it cuts out. Any ideas what the problem could be?
Yep,
Your filters are clogged. As a result the motor is straining and overheating, then a thermal cutout operates.
Clean the filters in the top of the vax and if you are ussing a cloth bag empty and wash ot. If a paper bag, replace it.
All should be well
Jun 29, 2011 | Hoover Vacuums
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
Hoover hygiene- how full does the bag get before the light goes on. I have been vacuuming every week for 3 months and the light hasn't gone on yet.
They usually pack the dirt in pretty tight! You can always check that the light is working by blocking the suction with your hand - if the light doesn't come on you need to get it serviced.
Jan 16, 2010 | Hoover Telios Canister Vac Vacuum
Dyson DC07. Problem:- switch the hoover on and it cuts out after approximately 1 second. Any ideas please?
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Nov 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
HOOVER WINDTUNNEL SELF PROPELLED OVERHEATING AND SHUTTING OFF
It sounds like it is overheating because of a blocked flow of air that keeps the motor cool. Check for a blockage from the area of the
roller brush through the hose to where it goes into the bag.
Tom
Oct 22, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover cuts out after 5 minutes and will not restart until its cooled down.
OK - so it cuts out because it's overheating. The cause of this is almost always a blockage. You don't say what model of vacuum this is, so I can't guide you where to look. If you've got flexible hoses, check them. Also check all filters and any other airways you can get at. If you are 100 percent sure that everything is clear, but the problem persists, then the motor's at the end of its useful life.
Sep 12, 2009 | Vacuums
Hoover fusion plus on/off button works on and off.
it's overheating.. there is something blocking air flow somewhere follow suction from floor to bag there's something there
Jan 17, 2009 | Hoover Plus U5435-900 Bagged Upright...
Flair motor shorting out?
There's a thermal cut-off when the unit has overheated. Mine does this quite often and I remedy it by emptying the canister and making sure the filter is clean, especially of lint and things that prevent good air flow.
Jul 07, 2008 | Hoover S2220 Flair Bagless Upright Vacuum
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
