Question about Home
Price Pfister Diverter and Hot/Cold Stems
My tub/shower uses a Tub/Shower compression Diverter part #: S10-385. I now need to buy the hot and cold stems. So, which is the correct part # for the hot and cold stems? 1) Is it the 910-374 ? 2) Is it the S10-375? 3) Is the S10-375 discontinued? 4) Does the 910-374 replace the S10-375, but BOTH will work? 5) Also, does the 910-381 Diverter replace the S10-385 Diverter? Is the S10-385 Diverter discontinued? My local Lowes store still carries the S10-375. Can I use that part for my hot and cold stems? Please answer all 5 questions so I can understand it all. And please let me know if the 910-374 and the S10-375 are the SAME part and are interchangeable.
3 Suggested Answers
bloues
  • 56 Answers
SOURCE: The cold water stop working in my shower. I have a
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
Posted on Jul 20, 2010
packrat1948
  • 528 Answers
SOURCE: Have a shower only no tub. replaced both the hot
Take the shower head off and see if the pressure is better or the same. If it is the same then you will need too look up-stream for blockage in the water lines. If it is better then replace or clean out the holes in the shower head. It may also have a filter screen before the shower head.
Posted on Apr 12, 2011
Testimonial: "I wasn't sure if that was the problem since I had just recently put a new shower head on, but it was the problem. Thank you for your help. "
My price pfister tub and shower value is only letting out hot water. cold water will not come out. This just started out of the blue. has been working fine.
remove the cartridge and replace it with a new one. They have cams and pistons inside that out of the blue the cam does not work and then you get only hot or cold water.
Best of luck Rich
Sep 06, 2011 | Price Pfister Plumbing
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
Hello. We have a Moen two handle tub/shower faucet. A little over a year ago it started to make a high pitched noise when on. Now the water flow to both the tub and shower are greatly reduced for BOTH...
sounds like the diverter inside the valve body is cloged with debris.
only wat to remedy this is to remove the valve and clean out the diverter, or just replace the valve.
Aug 05, 2010 | Moen 2919 Chateau Two Handle Tub and...
hope it helps
Jul 11, 2010 | Price Pfister R897EBK Brushed Nickel...
I have a older Delta shower head/tub combination with scald protection. It leaks from the tub diverter. Where should I start?
I'm assuming that you have a three handle faucet. You need to remove the diverter from the faucet body and while your at it remove the hot and cold stems from the valve body (the parts are inexpensive). Remove the seats inside of the valve body towards the back, replace with new ones. If stems are in good shape, just the washers and seats need to be replaces. If the brass on the diverter or on the hot or cold stems is pitted or marred, then replace the whole thing. The parts should be readily available at most plumbing supply places.
Nov 27, 2009 | Bath Unlimited DELTA INNOVATIONS TOWEL...
1 HANDLE TUB/SHOWER. WHEN YOU TURN THE SHOWER ON
The diverter is worn and needs to be replaced.
The diverter is the lever/button you pull/push to switch from shower to tub. When they get worn, they require more pressure to seal properly and divert the flow.
Aug 06, 2009 | Delta T13420 Chrome Classic Single Handle...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Home Logo
51 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
