Question about Lowrance Lms-525c GPS Receiver
GPS does not lock in -keeps searching
It has always worked in the area it is now failing It worked when it was stored for the winter
Warm weather cranking instructions?
After your saw sits for any extended period of time, it is suggested to drain all the old gas out of the tank and replace it with fresh mixed fuel. Currently we are being provided 'summer blend' fuel in warm weather and 'winter blend' fuel in the winter. All fuel now being 'oxygenated fuel' has a tendency to lose its oxygenation which changes the blend (for lack of a better description). Old winter fuel can make a saw diffficult to start in the summer and vice-versa.
I wouldn't suggest running fuel with a high blend of alcohol because alcohol has a tendency to 'draw' moisture from the surrounding air and you can end up with water in your tank or gas can.
Alcohol can also deteriorate rubber components and cause fuel delivery problems due to swollen or cracked lines.
Never store your gas container directly on concrete or directly on dirt because that will cause moisture to condense on the inside surface of the fuel container above the level of the fuel. Always store gas cans on a rubber mat or on a wide board.
Always keep the filter clean and sawdust out of the carb vestibule area to minimize contaminates entering the system.
I'd suggest a full choke and a few sharp pulls until the plug fires, then go to half choke and pull sharply again and get ready to finger the throttle a bit until it warms up fully.
Sep 15, 2015 | Poulan Wild Thing 2375 18" Gas Chain Saw...
GPS Garmin C330 is always searching for satellites but cannot lock onto them?
If the GPS device left unused for long time or moved very far without being on, it usually needs very long time star working again. This could be 10 minutes to perhaps 30 minutes. I suggest you put the GPS in an area where there is lots of open skies which is not obscured by tall buildings or large trees for a while. It should eventually start working. If not, try upgrading the firmware from Garmin website.
Feb 24, 2011 | Garmin StreetPilot C330 GPS Receiver
I have a 2008 touareg. the trunk has always worked perfectly until today when it will not open. I've tried the key, driver door button and trunk release. any ideas?
Are you in an area where it may be iced shut? This winter has already been nasty for some areas so If that may be the case heat up some water to boiling and pour it into the area where the lock would be. Rinse/repeat. Hope this helps!
Dec 22, 2010 | 2008 Volkswagen Touareg 2
I was in Dallas Texas and turned off my GPS. I arrive in Baltimore Airport and reinstalled my GPS. At this point of time it still showed the Dallas Airport area and would not resink up to Baltimore. I...
When its receives a signal from a satellite it receives also information about satellite positions in the coming days. When you boarded the plane you must have turned off the GPS, so it could not keep track of your position. You land a long distance away and turn GPS on. It starts to search for the satellites according to the information stored in it that pertains to their positions over Dallas. It is unable to lock on the satellites. And then it was able to receive GPS signals from other satellites and all fell into place.
Yes it will happen again if you travel long distances in a short period of time. If you cannot keep it turned on during the trip, you should try to update satellite positions through Internet after you reset the time zone.
You should also be patient, and give it time to find its bearings.
Jan 21, 2010 | Fine Digital FineDrive 400 GPS Receiver
DO I HAVE TO KEEP CHARGING SKYCADDIE THROUGH WINTER MONTHS?
No.
Store fully charged. Expect it to lose 5% of charge per month
Recharge before use
Dec 07, 2009 | SkyGolf SkyCaddie Handheld GPS Unit
Hooked up this spring but can't find satellites. Nothing has changed
Thanks for the comeback.
Problem was my antenna wire. Somehow the wire wore through where it went through the hard top. Probably due the the high winds we had this winter which caused the cover to rub and pull against it.
Thank you
CJ
May 16, 2009 | Garmin GPSMAP 235 Sounder GPS Receiver
My new garmin 260 is failing to identify nearby stores.
check this out
you can store you poi file on your garmin
and download them
www.poieditor.com
cool ha
Angel
Apr 03, 2009 | Garmin nuvi 260W GPS Receiver
Icn 520
I have icn520 - bought an external aerial for it off e-bay now get full strength signal evertytime within seconds - well worth about a tenner rather than ditching the 520 which is was about to do!
It was the windscreen causing the problem for me
Jun 07, 2008 | Navman iCN 520 GPS Receiver
Lowrance Lms-525c GPS Receiver Logo
16 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
