Question about Annovi Reverberi AR Pressure Washer Pump RKV4G40-PKG
I have a John Deere pressure washer with the AR RSV 4G40 pump; it will not pull up the soap any longer. I have only used it a few times, which it worked great, and now it doesn't work! Anyone have any ideas what the problem could be
2 Suggested Answers
SOURCE: won't build pressure
Sorry so late on this answer but how about a rebuild if you use this thing regular as a work tool you are going to have some maintenance on the pump itself, that will need seeing to. get a rebuild kit change some seals replace some valves and before you know just like new. also keep that engine up to snuff by performing scheduled maintenance such as the oil keep a good air filter in it and never ever set it up with fuel in it. And stay away from, mid grade and super in your tank, unless instructed by owners manual else-wise use regular that ethanol is bad bad on carburetors O7OUT
Posted on Feb 11, 2013
Low hydraulic pressure to raise implements 8650 john deere
Could be the charge lube in the rear differential. It supplies oil to main Hydraulic pump up front on engine. The charge pump drive can strip and not turn pump. To remove pump drive remove third link plate on rear frame, remove plug behind plate, pull out hex shaft, about 5 foot long and inspect.
Oct 01, 2016 | John Deere Garden
Ive got a john deere 4055. Has a new clutch and pto release bearings and piston. The pto will not ingage and there is no pto pressure.
did the mechanic that installed the new parts pre prime the hydraulic pump on install , ive had limited luck using another tractors pump on remote circuit to back feed on the return line to "externally) prime the pump , but it has worked a few times , worth a try if you have the means
Mar 28, 2015 | John Deere Garden
RRV 4G40 Annovi power washing pump is giving me zero pressure Motor runs but only a small stream of water when I pull the trigger How can I fix this
pump is blocked or valve faulty, or broken pump internally. remove cover check each valve first , if ok remove pump head . turn motor look for piston movement , if no movement, replace or repair pump head.
Apr 15, 2014 | Garden
Will not draw soap solution
Follow the pipe back to the pump and you will find a ball and spring inside.This could well be stuck closed if it has been stored for some time. Oil this part and it should draw soap again.
Jun 23, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
How do you use the tube for the detergent
Put the tube into a bucket with detergent that is recommended for your machine then put the wand into low pressure mode and if it has a valve where the hose connects turn the valve to the on position and pull trigger and watch to see if soap starts being drawn out of the soap bottle if it starts pulling the soap up continue to allow it to flow till you get your part soaked with soap, then let it set for 10 minutes then hit it with high pressure hose to wash off, when it is clean then put it on low pressure and pull hose out of bucket with soap and then allow the soap to be pulled out of tube and until there is no longer any soap coming out then store the hose for use later. some machines have a control valve at the end of the wand by turning the tip or pushing tip in or pulling it out some models requires you to use quick disconnect fan tips to lower pressure to use soap.
Jun 15, 2010 | Karcher G3025OH Pressure Washer
John deere 3800psi pressure washer will not siphon detergent. the water end does fine but cannot get any soap
The only way the washer will draw soap into the line is with either the black tip installed or with no tip in wand at all.There is a ball and spring inside of the pipe that the siphon hose hooks to so when you use the washer with alot or even a little pressure the ball is forced up and blockes off the soap inlet port.So if you use it with no tip in the inlet port is open cause the ball isnt being forced up by back pressure.I hope this makes sense.
May 18, 2010 | Dewalt 3800 PSI Pressure Washer
I have a John Deere AC2600Gh power washer and I can't get the soap to work everything else works great it just won't **** the soap up when I am pressure washing I know that it must be something simple to...
Soap will only siphon into hose if there isnt any pressure in the hose attached to the wand.Remove tip from wand and see if it draws soap into hose,back pressure in wand hose will cause the spring and ball to seat/close off the inlet line for the soap otherwise water would blow out of soap line.
May 17, 2010 | Karcher 2500 PSI Pressure Washer
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
Getting soap to come out on john deere pressure washer
The cleaning solution pickup will only work with the wand in the low pressure setting. Try pulling out on the end of the spray head.
Regards,
Carl
Feb 24, 2009 | Garden
Annovi Reverberi AR Pressure Washer Pump RKV4G40-PKG Logo
277 people viewed this question
Top Annovi Reverberi Garden Experts
Bill Boyd
fasteddy
fasteddy
Level 1 Expert
jeff chenault
jeff chenault
Are you an Annovi Reverberi Garden Expert? Answer questions, earn points and help others
