Question about Stihl Cutoff Saw Piston Cylinder Ts 350 360 08 S
Stihl TS 08, which way should arrow on top of piston point when replacing it?
3 Suggested Answers
  • 623 Answers
SOURCE: I bought a rebuild kit for a Stihl TS400 and the
I believe the arrow must be installed facing the exhaust.
Posted on Jun 07, 2010
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
Which way does the arrow point on a stihl piston ts400
the arrows on all pistons face to the front of the engine
Apr 19, 2014 | Stihl Ts400 Cut Off Saw Piston Cylinder...
Ts 410 won't start
check for spark, check for fuel, if you have both poss pot and piston
Apr 13, 2014 | Stihl Ts 410 420 Cut Off Saw...
Bt 360 stihl
possibly a fueling issue, check fuel filter, tank vent and possibly replace carb diaphrams.
Feb 25, 2014 | Stihl 08s Ts 08 350 360 Bt 360 Clutch Hub...
Setting the timing gears on stihl fs110r gas trimmer
Hello there, on the flywheel, between the fins, to the right of the magnet there is an arrow. This arrow points toward the closest ignition unit mounting screw (centre line of the engine) or spark plug when the piston is at the top of it's stroke - which is ware it needs to be to set the cam timing. On each side of the face of the cam there are two arrows facing towards the gear teeth, these line up with two raised lines cast into each side of the cam casing. Another way to align the two components is to set the pointy part of the cam lobe straight up or straight down. Reassemble the followers, push rods and rockers, sparingly apply a good quality automotive sealant to the cam cover - use the groove as a guide. Once that has been done the valve clearances can be set - 0.1 mm with the piston at the top of it's stroke and with the valves fully closed, not on the rock ie exhaust closing as inlet opening. You should replace the cork gasket and copper sealing washer as well. These engines will not run if air is getting in passed a leaking gasket etc.
Good luck.
Nov 11, 2013 | Stihl Garden
Stihl Repair Manual
arrow points towards exhaust, direction of gasses http://www.mediafire.com/download/56zr9s967sf9a98
Oct 22, 2013 | Stihl Garden
What why dose arrow on piton go on a ms 170 to front or rear
The 'Arrow' on the piston always points in the direction of air flow through the cylinder. So it should be pointing towards the exhaust port. :)
Mar 08, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Homelite 360 chainsaw will run like 20 minute then quit and will not run. then cool down it will run again and short time quit again
It sounds like the coil has gone bad. The winding in the coil are coming loose when it gets warm and making good contact when the unit cools off. I would replace the coil, and see if it will run and quit like it did previously.
Sep 24, 2010 | Stihl Chainsaw Cutoff Saw Piston 08 Ts 350...
Hi there; my stihl ts 420 does not start easily
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
Stihl Cutoff Saw Piston Cylinder Ts 350 360 08 S Logo
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
Spud Howell
ray gallant
Are you a Stihl Saw Expert? Answer questions, earn points and help others
