Question about Precor EFX 546i Elliptical Version 4
Precor error 12 - Precor EFX 546i Elliptical Version 4
  • Precor Master
  • 914 Answers
Precor Error 12, Watchdog (Lower PCA) Probable Cause 1. A failure in the lower PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the low voltage power supply of the lower PCA to be too low.
3. A failure in the upper PCA that overloads the lower PCA low voltage power supply causing it to be too low.
Corrective Action
  1. If the error message is continually displayed when the unit is powered up, the upper PCA needs replaced.
    External causes may make the error appear intermittently.
    1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
    2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittently.
  2. Determine if the interconnect cable is the cause by substituting a know good cable in place of the current cable. For test purposes, the substitute cable needs to be connected directly between the upper and lower PCA's, without routing the cable internally.
  3. Determine if the upper PCA is the cause by substituting a know good upper PCA for the existing upper PCA.
Precor Error Code 12 12 Watchdog Lower PCA
Posted on Jul 28, 2014
Precor error 3
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Feb 22, 2014 | Precor Exercise & Fitness
Error41
Precor Error 41, Lift has not Responded in Acceptable Time Probable Cause Error 41 was present in early software versions and is no longer being used.
Corrective Action If you encounter a unit that has software with an error 41, diagnose the same way you would if getting an error 40.
Precor Error 41
Jan 29, 2014 | Precor 9.21 Treadmill
Error codes for 9.17
This link will take you to some common error codes found on most Precor exercise machines:
Error Code List for Precor Fitness Equipment
Dec 12, 2013 | Precor Exercise & Fitness
Precor treadmill code e3 is on
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Precor error code 1
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Error 12 appears on display? What do I do?
Corrective Action
Jul 12, 2011 | Precor EFX 546i Elliptical Version 4
What is error 50 on the precor efx546
Error 50, Too Much Brake (Magnet) Current
The problem maybe lower board related or improper signal is being translated Call Precor @ 800-347-4404
May 11, 2010 | Precor EFX 546i Elliptical Version 4
Precor uses the same error codes for all of their units. Error code 50 is for excessive brake (eddy current magnet) current.
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
102 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
