How to get answer in decimal from cannon F-719sg calculator
SOURCE: When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Posted on Dec 08, 2008
SOURCE: The calculator won't convert fractions into decimals
Are you using a ti-89? If so, check your mode settings and change Exact to Approximate.
Posted on Feb 09, 2009
  • 3 Answers
SOURCE: need to program to fifth decimal place
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Posted on Jun 11, 2009
  • 7993 Answers
SOURCE: Setting the default value of my calculator to display decimals
Since you bent on deactivating the very features that make your calculator so versatile and so powerful, here it is.
Press [SHIFT][MODE][2:LineIO] and you will see no more fractions, nor radicals etc. You asked for it.
Hope it helps.
Posted on Oct 18, 2009
Testimonial: "I bought the calculator because it was on sale and I like Casio calculators; not for its fractional abilities. I can easily switch it back now. Thanks"
  • 7993 Answers
SOURCE: answers in decimals
The calculator has two Input/Output modes, MthIO and LineIO. In MthIO the results are displayed as fractions or as radicals or a mixture of fractions and radicals. What it means, is that in MthIO the calculator does exact calculations. Radicals in denominators are gotten rid of by rationalization, fractions are reduced to the same denominators before addition or subtraction. Fractions are reduced to simplest form.
In LineIO all results are displayed as decimal numbers.
If a result is exact (fractions and radicals) it can be changed to decimal form by pressing the S To D key, the one above the DEL key.
MthIO is the default IO mode. To set it, press SHIFT MODE and select 1:MthIO. To set LineIO as the IO mode, press SHIFT MODE and select 2:LineIO
Posted on Jan 20, 2010
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
HOW DO I SET THE DECIMAL ON SHARP EL-1197PIII?
Up Arrow: Answer is rounded up
5/4 key: Answer is rounded off
Down arrow: Answer is rounded down
The decimal will float if the calculation is multiplication or division
If the decimal selector is set to F then the answer is always rounded down
Aug 26, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
It wont give me the value when i multiply like 6 x pi
Your calculator may be able to use the symbol Pi. If it gives you a result with Pi, you should convert it to a decimal approximation. There must be a key to convert.
Nov 12, 2013 | Canon F-719SG Green Scientific Calculator...
Casio fx-82ms calculator does not give me an answer when i use the percentage button . example if i type 0.25/ 100% i get 0.25 instead of the right answer 25
Here is a sample of the percentage calculations that the calculator can perform. You will not see among them the conversion from decimals to percentages.
To convert from decimals to percents move the decimal mark 2 places to the right and append the % sign.
To convert from percents to decimals, move the decimal mark 2 places to the left.
Sep 28, 2013 | Casio FX-82MS Scientific Calculator
When I enter 55/2 - the answer appears as a fraction. I would like for it to appear as a decimal. I know I can convert the answer using the SD key, but I would like the initial answer as a decimal.
To get the result in decimal format, press [SHIFT][=] instead of just [=].
You can also configure your calculator to show only decimal results:
  1. Press [SHIFT][MODE] to access the (SETUP)
  2. Select [2:LineIO]
Aug 12, 2010 | Casio FX-115ES Scientific Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
My calculator is returning an answer with a 7 for division
You need to set the number of decimal places to 1 or more.
• Press [2nd] [MODE] and scroll to FLOAT.
• Press the right arrow key until the number of decimal places needed is highlighted.
• Press the [ENTER] key.
For 2 decimal places, 2 should be highlighted. All answers will then be rounded to 2 decimal places.
• Press [2nd] [QUIT] to return to the home screen.
May 03, 2010 | Texas Instruments TI-30X-IISTK Scientific...
Hope this Helps
Nov 07, 2008 | Casio fx-300ES Calculator
CFX-9850GaPlus
I think the F-D function only works one direction from fraction to decimal. Decimal to fraction is a non trivial calculation that can have multiple answers so doesn't lend itself to a calculator feature.
Jan 04, 2008 | Casio FX-115ES Scientific Calculator
108 people viewed this question
k24674
