Question about Canon Pixma Mg3120 - Multifunction Printer / Copier / Scanner Color
Canon scanner error 2.157.50 - Canon Pixma Mg3120 - Multifunction Printer / Copier / Scanner Color
Error e42 22
Apr 24, 2011 ... E40 20 = Other hardware error. E42 22 = Scanner error. How to reset CANON WASTE INK COUNTER MP160/MP145 Before you reset the ... canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html canonprintersink.com/error-code-printers-reset-canon-mp145-mp160.html
have just checked this site and I am sure it will help you
Feb 20, 2012 | Canon Office Equipment & Supplies
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam shyam.lal@teamcomputers.com 9210845186
Sep 13, 2011 | Canon DR-2050C Path-Through Scanner
My dr-x10c scanner gives an P007 error code i have tried cleaning the rollers but the error stills keeps coming back. do you think that it's time ireplace mty exchange roller kit???
Solution: I had the same error P007 on a Canon Scanner. Switched off the scanner, Opened the scanner. Located all of the sensors. Sprayed Platenclene spray and used a soft cloth and cotton buds to clean the sensors. Switched back on the scanner and the error was gone and its scanning perfectly. The error P007 is a result of dirty sensors!
Nov 19, 2010 | Canon Office Equipment & Supplies
I have a canon 6080 scanner. getting a error "no
Clean the two 'black dots' in the paper tray, just under the roller. They are actually paper sensors. Try 'page counting'. If this works, the scanner is okay. If the problem still persists, try reloading the scanning software.
S. Mohan, Chennai, India
Nov 17, 2010 | Canon DR-6080 Path-Through Scanner
Canon CanoScan 5000F Flatbed Scanner error 15. no manual.
Click on the link below to download the software, drivers, and owners manual for the Canon CanoScan 5000F Scanner:
http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_5000f
Oct 18, 2010 | Canon CanoScan 5000F Flatbed Scanner
Canon dr5020 c02 error
When the top cover is open you get message C01, when the top portion of the top module is not in position, you get C02 error.
S. Mohan
Mar 26, 2010 | Canon DR-5020 Path-Through Scanner
Error code : 0x24050010 Canon scan N340P
I don't know what model of canon scanner you have, so I am unable to provide a link with the download, but try updating and reinstalling the canon scanner drivers from their website and see fi that wokrs
Jul 10, 2009 | Canon CanoScan N640P Flatbed Scanner
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Are there any other words along with the error?
Make sure the scanner is unlocked.
Does the scanner make any noise when you attempt to scan?
If possible, try the scanner on another computer.
Was the scanner working before?
What OS are you using?
Download the delete driver application and uninstall the drivers. Also, download the most current drivers and reinstall. You should also download and install the most current version of Toolbox.
Apr 19, 2008 | Canon CanoScan 5000F Flatbed Scanner
Canon MP530 - "scanner error" mesage
I've some problem whit the printer and my firs check printer make only bips
Sep 17, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma Mg3120 - Multifunction Printer / Copier / Scanner Color Logo
160 people viewed this question
old marine
old marine
