Question about Dell Alienware M14x Notebook
Enable lan network - Dell Alienware M14x Notebook
  • Dell Master
  • 32,281 Answers
You need to install the LAN driver.
You can download the LAN and device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on May 04, 2013
Lenovo Z70-80 problem with wifi (don't show). Please do you know why? Thanks for any answer
see p18 of the user guide, downloadable from Lenovo website for how do this in win 8.1 (selt other o/s presumably)
it says
Connecting to wireless LAN - - -- - - - -- - - -- - - - -- - - -- - - - -- - - - -- - - -- - - - -- - - - -- - - -- -
Enabling wireless connection
To enable wireless functions, do one of the following:
• Press F7 ( ) to disable the Airplane mode if the mode is enabled.
• Open the charms, and select Settings ? to open the Network
configuration page. Toggle the Airplane mode switch to Off.
Connecting to a wireless LAN
After wireless has been enabled, the computer will automatically scan for
available wireless networks and display them in the wireless LAN network
list. To connect to a wireless network, click the network name in the list, and
then click Connect.
Note: Some networks require a network security key or passphrase for connection. To
connect to one of those networks, ask the network administrator or the Internet
Service Provider (ISP) for the security key or passphrase.
Jan 15, 2016 | Lenovo Computers & Internet
Wireless lan disabled. where is button to enable
for windows XP - go to control panel - network connection - eneble wireless LAN
for windows vista - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
for windows 7 - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
Mar 28, 2010 | HP Pavilion dv5tse Notebook
No lan connection
You can enable it again, just goto control panel, open network connection, there will be local area connection icon, Right click on it and click on enable.....
If there is problem again use motherboard cd and install lan card drive again...
Feb 11, 2010 | Intel D915GAG Socket 775 Motherboard -...
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
My D430 stopped recognizing my LAN card. This
Changing your CMOS battery will reset your BIOS, you just need to configure your bios to enable Local Area Network connections, to do this go to CMOS setup and find network setup utility and enable the LAN, hope this helps...
Oct 21, 2009 | Dell Latitude D420 D430 8x DVD+RW / CDRW...
I have aa ACER X3200 and the net work adapter will not recognize the LAN plugged in. The LAN source is active and works on other computers I have.
Check the Network Connections (in control panel) to see if the LAN connection is enabled. If not there, you'll need to setup a new network connection. If it is there, right-click the connection icon and choose enable.
You can also check the Device Manager to see if the network adapter is listed and working without errors.
Oct 03, 2009 | Acer Aspire X3200 PC Desktop
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
How to enable lan of intel board lan is not installed showing
If you are using a windows XP as an OS...make you have loaded all your drivers inclucing the LAN. Secondly from the START go the control panel--network and internet connections--network connections--you'll see the LAN icon/s.Right click on it and select Enable/Disable.
Jun 07, 2009 | Intel D845GVSR Motherboard
Lan connection between two desktops
if you mean in-game, go to multiplayer, then select Local Area Network (UDP)
Dec 18, 2008 | Blizzard Entertainment StarCraft Brood War...
Sony PCG-4g1m
Plug in the LAN cable (CAT 5) into your laptop network jack. Make sure the other side is plug into the network outlet jack. Now confirm that you have a link on your LAN adapter, if your laptop has lights for the LAN adapter built in. If it doesn't don't worry. If its connected windows xp will say if its connected or not. If its connected it will try to find a IP address. Make sure DHCP is enabled (Should be set as DHCP as default anyways) if your laptop doesn't get and IP address then there's something wrong with the network your connected to and not your laptop. Contact the system administrator (IT guys) in charged of that network.
**** IF AND ONLY IF***
IF there's no network icon in the taskbar tray then your network adapter is disabled. To enable this right click the network icon on your desktop and select properties now a windows opens up and right click on your LAN adapter and select enable... let windows do its magic and you should be back to normal.
GOOD LUCK!
Aug 19, 2008 | Computers & Internet
Dell Alienware M14x Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
