Question about Honeywell TH2110D1009 PRO 2000 Programmable Thermostat, Heat/Cool or Heat Pump
Honeywell pro 2000 thermostat
Ambient temperature stays the same on the display even though the temperature in the house varies. Just had this installed.
  • 85 Answers
SOURCE: my honeywell thermostat Modle: RTH7500D
If your manualy setting the program and it kicks itself off, then your therm is bad, look for your warranty paperwork, or call the distributer and give them model and serial, they can point you in the right direction. If your setting a temp and not manualy holding, then it will set back by default. Check your other settings, ensure they work as well..
Posted on Dec 05, 2008
  • 118 Answers
SOURCE: Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Posted on Oct 28, 2009
Testimonial: "Thanks a lot for your help. I'll try that -- very simple!"
heatman101
  • 43501 Answers
SOURCE: Incorrect ambient temperature on Honeywell Model RTH221B
Check in your manual for the thermostat. By pushing a combination of buttons you can get into the advanced installer menu. From there you can make an adjustment to correct the temperature.
Posted on Nov 12, 2009
shastalaker7
  • 1515 Answers
SOURCE: I had a new thermostat installed was not working
Hi, even though Honeywell do make good products, I would return this heat only stat and replace it with a heat/cool stat even though you have heat only. If you want to stay with the mechanical style stat, I would go with a white Rodgers 1F56-444 mechanical stat. Inexpensive but good quality. When you wire one with cooling on it, you will see on the new stat terminals such as Rh and Rc, W, G, Y, and some with O and B. The Rc and Rh will have a jumper wire connecting the two. Leave it on! If you have 2 wires maybe a red and white, connect the red to either one of the R terminals as the are connected. The white will go to W for heat. If you have 3 wires and the third is green, it will go to the G terminal. If not, no worries. In cooling the Y is for compressor, G for fan and Heating W for heat. Red is you're 24 volts. Get rid of that stat and get a good one. If you do go with the white Rodgers and you find the temperature does not match the room temperature on the cover of the new stat, you can adjust the needle pointer on the cover of the new stat to the exact room temperature. This is what I recommend to you. It will solve your headaches. There is a small screw slot on the back cover for this adjustment.
Keep me posted on the out come.
Sincerely,
Shastalaker7
Posted on Jan 18, 2010
  • 98 Answers
SOURCE: I have a Honeywell programmable Thermostat (an
What is the model number of the thermostat? What may be happening is the humidity control is trying to satisfy the humidity setting by running the a/c. In the installers set-up, there should be a setting to determine how long the system should run to satisfy humidity setting. I typically set thermostats for a 3 degree droop. Meaning it'll only drop 3 degrees below set temp. Also check your humidity setting to be sure it's not set too low. It should be set between 45% and 50%.
Posted on May 09, 2010
What is ambient temperature is below 32
be more specific??? what model is the thermostat, what set up is your heat>> gas oil electric
Feb 16, 2015 | Honeywell RTH7600D Programmable Thermostat
Compressor relay switch
What temperature is this heat pump being run at? If it is low ambient temp outside this may be running in what is called defrost mode to where the compressor will run without a call for heat. This seems normal to me as long as the setpoint temperature is being reached.
Dec 25, 2013 | Honeywell Heating & Cooling
I had a new thermostat installed was not working correctly and was replaced with another. This one is even worse than the other. To get the furnace to come on the house temperature on the thermostat reads...
Sincerely,
Shastalaker7
Jan 12, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
Dec 28, 2009 | Honeywell Programmable Thermostat Heater
I have an older square mercury Honeywell thermostat in my apartment. Furnace works fine in the main house using same model Honeywell thermostat. There is no heat coming from the apartment baseboards. I...
should have 24 volts @ t-stat. if tis is a boiler system it could have air in the zone that stays cold. bleed the radiator out and this should get the heat into the area you want.
Dec 06, 2009 | Honeywell Programmable Thermostat Heater
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Honeywell TH2110D1009 PRO 2000 Programmable Thermostat, Heat/Cool or Heat Pump Logo
18 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
