Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Roper RS25AGXNQ00 The refrigerator food is freezing
2 Suggested Answers
  • 257 Answers
SOURCE: roper # RS25AGXNQ00 the freezer side too cold
Make sure the settings are on the recommended setting, If so check to see if the freezer bottom is frozen over with sheet ice, if it is than you either have a leek in the ice maker or a clogged defrost drain line. The excess ice obstructs the air flow from the freezer to the refrigerator making the freezer to cold and the refrigerator not.
Posted on May 20, 2011
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
RS25AGXNQ00 roper icemaker leaking. Bad solenoid?
if what you see is water/ice build up overflowing from the i/m yes indeed the water valve isn't fully closing and needs to be replaced
Jul 20, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
Roper RS25AGXNQ00 icemaker leaking. It's not the tray, could it be solenoid bad?
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jul 20, 2011 | Refrigerators
Roper # RS25AGXNQ00 the freezer side too cold around -22+ and the fridge side 51+ also found ice forming inside the air diffuser. Any suggestions?. Thanks
May 20, 2011 | Whirlpool Refrigerators
Vegetables are freezing in lower bin Model # rs22aqxmq
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Apr 20, 2011 | Roper Refrigerators
Freezer too cold turned control in fridge down to 1 waited a day cant lower freezer temprature
heatman101
Feb 19, 2011 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
The fridge fan is making a grinding noise like the fan is barely turning. What could be the cause?
heatman101
Jan 23, 2011 | Roper Refrigerators
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
RS25AGXNQ00 defrost timer
Hi, The timer board is located in the control panel. Remove the control knobs and then pry the front plate with a thin flat blade. It will pop off. You will find 2 screws behind the plate and 2 on the back side of the control panel. Here is a picture.
Please let me know if this helps you.
Thanks
Jul 13, 2009 | Refrigerators
My roper refrigerator(2door)constatly freezes up--WHIRLPOOL PROD.
Check the defrost timer, mark it and see if the dial rotates. It takes a while to see if it moves. Make sure food in the freezer is not blocking the openings for air to move around.
May 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
