Question about GE Monogram ZDWC240NBS Stainless Steel Wine Cooler
Cooling freezing up. ice forming on back
5 Suggested Answers
  • 60 Answers
SOURCE: freezer not working ice not forming
Possible it's not getting cold enough. Try adjusting to coldest setting to see if that works.
If mechanically inclined suggest replacing compressor or see if possible to refill freon.
Can check local repair shops for parts
Posted on Apr 06, 2009
heatman101
  • 43501 Answers
SOURCE: GE GSH22KGMB side by side refrigerator freezes up
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
walterkunesk
  • 683 Answers
SOURCE: refrigerator side not cooling.
have you tried cleaning the condensor coils? let me know.
Posted on Apr 19, 2011
rickead1
  • 1998 Answers
SOURCE: the refrigerator has frozen on the back side of freezer and has stopped freezing. The other side is not cooling. Ice maker stopped.What is going on?
The frozen on the back side of the freezer is due to your unit haveing a defrost issue where either the defrost thermostat which is the most popular to show a fault in this type of situation, or the defrost heater, or the defrost timer or adaptive control has a fault . If you have a multimeter you can perform and ohms test on the thermostat which should read around .50 or higher and the defrost heater which usually is around 26-28 ohms. If you had a 0 reading then this would tell you which piece has a fault. I will await your reply as to your finds.
Thank you
Rick
p.s these parts are located behind that inside rear wall panel which is removeable if you were to see any ice up condition on the evaporator coil this would confirm your defrost issue and you would first use a hair dryer to defrost the evaporator coil of all ice.
Posted on Nov 19, 2011
How do I fix my icemaker?
if its new it can take up to 48 hrs to produce its first ice cubes, this is due to timer in the ice maker
Nov 07, 2015 | Bosch B26FT70SNS - 800 Series Standard...
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Need to replace defrost timer for Hotpoint refrigerator model CSX 20 EASA WH need to know how it look
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 19, 2011 | Refrigerators
The freezer compartment doesn't work properly.Ice is formed on the back and food won't reach freezing point. ????
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Refrigerators
GE GSH22KGMB side by side refrigerator freezes up and doesn't make ice and forms ice on the back wall of freezer and veggie drawer freezes.
heatman101
Aug 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
WATER IS LEAKING ON INSIDE SHLEVES OF REFRIGERATOR & THEN TURNING TO ICE. I DON'T HAVE AN ICE MAKER water is collecting on left side only
This is due to your fridge not cooling correctly. When the temp drops low enough, condensation forms. When the cooling picks back up, it freezes. Make sure there is nothing blocking the door. Also check the weather strip around the door to ensure it's seated properly. Over time, these strips become wore out and out of of shape causing air to leak.
Nov 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Dehumidifier freezes up
Most dehumidifiers need warmer air to work properly. The temperature in a basement is usually 60 - 65F; too cool for standard models. You could buy a "basement" dehumidifier. They're designed to work at lower temperatures; some as low as 40 F. Costs are about the same as a standard dehumidifier; you just have to find it.
For a cheap fix, try this; it seems to be working for me.
Since the condensate coil (the one icing up) is cold, the air entering it is too cool and the condensate frosts up the coil. Additional condensate freezes to the frost and before you know it, you've got a block of ice. Since the air coming out of the front is very warm take a large piece of cardboard around 6' x 3') and form a V. Placed it in front of the dehumidifier so it channels some of the warm air back to the rear where it warms the moist air up before it hits the cooling fins. It's helped keep the ice down.
If you want something attractive, any screen that redirects some of the air back to the rear will work. Just leave the top open so it doesn't get too hot and the some of the drier air gets out into the room.
Jul 02, 2008 | GE AHG40LJ Dehumidifier
GE Monogram ZDWC240NBS Stainless Steel Wine Cooler Logo
50 people viewed this question
Top GE Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a GE Furniture Expert? Answer questions, earn points and help others
