Question about Breville Coffee Makers & Espresso Machines
Bes860 filter light flashing
The filter light keeps flashing between single and double, can't get the grinder to work or stop this light flashing ? Anyone have any ideas?
3 Suggested Answers
SOURCE: I have a delonghi magnifica and it has stopped
I had the same problem and I had to replace the whole heater - this was two years ago and it has just gone again at £40 a time I am not very happy
Posted on Aug 23, 2010
  • 232 Answers
SOURCE: With the BES860 set to Dual Wall for full
If your using the dial gauge with a dual wall basket, you need to leave the dial in the dual wall setting. If you move it beyond the dual wall setting, you are basically adding more volume to the basket. Leave it in the dual wall setting for dual wall baskets.
Otherwise it may be faulty, it could be your grind setting, try it on 13 and see how it goes.
Posted on Jul 29, 2011
Grinder does not work, keeps blowing fuses! Can I fix it?
You need to return it for repair or buy a new one.
Nov 24, 2015 | Saeco VIA Veneto Combi
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
My breville bes870xl filter light won't stop flashing single and double. I've unplugged the unit and plugged it back in and turned it on and it still continues to do this.
PDF]Getting to know your machine - Breville
https://www.brevilleusa.com/media/.../BES860XL.pdf
Translate this page
rested coffee beans produce espresso with much more taste .... filter size you select, and along with the GRIND. AMOUNT dial ...... create steam. When the steam lightstops flashing it is ready .... cappuccino machines is purchased. THE RIGHT ...
Dec 07, 2013 | Breville Coffee Makers & Espresso Machines
Krups burr coffee grinder - When I push the power button it flashes on briefly and then stops. It has briefly ground some beans so it working to some extent. Any ideas what is causing the grinder to...
Empty the grinder and see if it will run with no coffee bean in it. Some times debris will get caught in the grinder because it got mixed with the beans from the factory. If it runs your good to go. If not then the mother connection are not solid and it will run off and on at will.
Oct 14, 2013 | Krups Burr Coffee Grinder
Hi my breville barista express does not grind the beans, and the "single/double" light is blinking, what is the problem?
My wife tried to make my coffee and long story short, she removed the lid to "move the beans around"..The grinder stopped working and the filter size lights began flashing intermittently. After taking the whole thing apart, the only REAL problem is that the lock mechanism inside the hopper came unlocked. So put your machine back together and "lock" the hopper. The lights will stop flashing...lets hope
Sep 26, 2013 | Breville Die Cast 800ESXL Espresso Machine
I have a single speed Delta 8" bench grinder. How
as for slowing it down, no problem. Hook it to a cord with a dimmer switch connected to it. Make sure your running with the same power rating though. As for a dripper, no ideas just yet.
Mar 10, 2011 | Delta ShopMaster 8in Grinder with Light...
Jura F70 Grinder stopped working
The switch or photo sensor is not sensing any beans present.
So it can't continue
Use torch to inspect bean entry area
Small brush etc
Apr 18, 2010 | Jura Capresso Coffee Makers & Espresso...
Saeco: grinder stops grinding
Hello, This may be the solution for you: having removed the ceramic grinder to clean out the unit, one of the wires on the grinder had become removed (the "center wire") on the connector. The 2 outside wires were sufficient to give me the illusion that the grinder was connected correctly, however it would only run for a half second and then coast to an annoying stop.
Check all 3 wires that connect to the grinder and make sure they are making contact.
Jun 02, 2009 | Saeco Incanto Rondo
I am using the Jura Impressa E 80 Cappaccino machine. It is a and 1/2 years old. After machine stopped working and after a regular maintenance scedule I cleaned and descaled my machine (even though there...
Pill clean your machine.
Take out the filter for this experiment
Try adjusting your grinder to the full course setting. You will have to make three or four cups before you see the results of the new setting.
If the flow comes back to normal and the light problem goes away the problem was your grinder was set too fine. Replace the filter and try a few more shots. If all the water leaked out of the filter the lights will come on one time until the filter is purged of air and you should be good to go.
If you still have the lights coming on you have some type of internal restriction a technician will have to clear it . We repair Jura Capresso.
Jul 06, 2008 | Jura Capresso C1000 Espresso & Coffee...
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
Coffee Makers & Espresso Machines Logo
76 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
