Question about Garden
Hustler zero turn mower stopped all forward and backward movement. Engine runs and blades turn. When I try to move it just coasts as if in neutral.
    New Friend:
The above answer from hroberthhelped me. My belt had come off of the pulleys. Got it back on and I'm back in business
Posted on Oct 10, 2016
2 Suggested Answers
SOURCE: Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
Posted on Apr 05, 2010
How do i fix my zero turn mower, will start,if blade knob is turned on kills engine, will not move with sticks when running , key will not kill engine.
this sure sounds as if you have a seat switch issue , this is a safety device to make sure theres an operator that weights more than 115 lbs in seat , the blade engauge problem and non movement tells me this
May 06, 2015 | Toro TimeCutter SS5000 zero turn mower
It will run backwards but not forward
If you are able to move in reverse but not forward, you need to adjust the levers. First you will need to elevate the rear wheels and set the neutral. This will then allow you to set the levers for proper forward and reverse movements.
May 03, 2015 | Husqvarna Zero Turn Mower Z5426
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Have a 19 hp john deere zero turn riding mower. starts up, blades turn, has oil. will not move forward or backward. does the hydrolic oil level have anything to do with that?
ck on traction motors for lever or nut to release fluid. Can you move mower with engine off?
If so, this is your what is wrong traction motors
are disengage
Aug 30, 2009 | Garden
Suddenly stopped driving...
Check for a worn belt first.Then check the linkage. Next jack the unit up and try to run it forward and reverse with the engine running.If there is any movement at all in either direction then check the fluid level to see if it is up to the top.The worst case is the hydro. unit has a stuck check valve or something broken inside.Hope some of this helps. donnyb60
Mar 23, 2009 | Garden
Garden Logo
1,486 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
