Error 111 ERR_TUNNEL_CONNECTION_FAILED - Computers & Internet
Microwave not working stating error 3 or error sensor or just coming on by itself. we have tried shutting down circut breaker
Hello
"ERR 3" means that the magnetron units have failed in the microwave. Food will not cook or heat up when the microwave is in use.
This code is different than "ERR 1" or "ERR 2" because with those the microwave is still operational. "ERR 3" means a complete failure.
The magnetron is the main source of power and heating in a microwave. Magnets work inside a magnetron tube to create the heat and voltage needed to cook items.
Bring the microwave back to the retailer or a repair shop for service. You may also consider purchasing a whole new microwave if the prices are cheap enough.
Oct 04, 2011 | Microwave Ovens
G E microwave model # JVM1190BY has reading sensor error or error 3 or at times just starts up when we are not even using. tried shutting circut breaker....whats going on
Hello
Your-Freedom - OpenVPN - SMTP server with SSL
Unfortunately XP is no longer supported.
Feb 27, 2017 | Computers & Internet
Pstopdffilter/pstocupsraster failed with err
Obviously this is an error coming from Adobe and not the printer. So I was start with Adobe and see what solutions they have to offer. Also, maybe I missed it somewhere, but you didn't say what OS you're using. I'll assume mac since I thing that I've seen that error related to Mac and Adobe Reader. One thing you might try is to use "open with : preview" and print from there. Don't know if that will work or not, but it's worth a try. In any case, I would still inquire through Adobe for possible updates or fixes.
Feb 05, 2010 | Canon PIXMA iP90 Mobile Printer
Network error IOException: Connection refused: connect
Please check that you are on the same sub net and that your network setting correspond to those required by the server including matching access passwords etc.
Aug 19, 2009 | Microsoft SQL Server 2000 Standard Edition...
Java.sql.SQLException: Network error IOException: Connection refused: connect
I too was facing the same problem as mentioned by you and couldn't connect through telnet localhost 1433.
Solution : Just go to SQL server configuration manager----SQL Server Network configuration----Protocols for SQLEXPRESS and in that right click on TCP/IP and in properties field make all TCP/IP port to 1433 which is blank. Start and Restart the SQL server and you can telnet localhost 1433 and it works. Hope this will help.
Ghanshyam
gimatpune@hotmail.com
Aug 07, 2008 | Microsoft SQL Server 2000 Standard Edition...
Won't connect to the Internet
If you are using a dialup connection, the ethernet connection would not have anything to do with your problem. Be sure the cable is plugged into the line socket. Take a repular phone and plug it into the telephone socket on the computer and see if you get a dial tone. Be sure you have entered the number correctly including a 1 and area code if required. You may want to call the number your computer is trying to call to see if you hear modem tones ( to be sure the number is correct). If all that is in order, your friends are probably right and your modem is bad. It may be covered under warranty.
May 06, 2008 | E-Machines eMachines Desktop PC
Dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Feb 28, 2008 | Meiko FV 40.2 Dishwasher
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
