Question about Teac MP-111 MP3 Player
RCA PEARL MP3 PLAYER NOT SHOWING UP IN MY COMPUTER AS A DRIVE
When I connect it to my home pc it says "new hardware detected" and it shows up in Device Manager and states device is working properly but does not show up as a drive in MY COMPUTER. The display on the MP3 player says "USB TRANSFERRING" and it should display "USB CONNECTED". On my pc at work it works properly. I running XP SP 2 on both computers. It seems to be hanging up on my home computer. Any suggestions?
  • 2 more comments
  • Litos Mar 12, 2008
    my mp3 player is showing as connected in my computer but my media player says not connected
  • KBabii Feb 05, 2009
    my mp3 player is showing as connected in my computer but my media player says not connected and it isn't showing up in my documents either
    different mp3 though
  • dogsmart06 Mar 17, 2009
    Okay so i insert it to the computer and it says "device not detected" what do i do?
    is it broken?
  • Anonymous May 09, 2009
    hiiiiiiiii
SOURCE:
  • 22 Answers
SOURCE: how to reset
The best way to fix your problem is to connect to the computer go to My Computer find where you are connected and click on the right of your mouse you will find the menu which will have in it format. Just reformat you mp3 and you will be very happy with your mp3 and be clean and green again
DGW
Posted on Dec 27, 2007
SOURCE: Pearl RCA MP3
never EVER buy another RCA product-THEY SUCK!!!!!!!!!!!!1
Posted on Feb 19, 2008
SOURCE: windows media will nt detect my mp3 pearl (RCA
Quue I had many of the same problems as listed above. what worked for me was to go here and download the firmware upgrade installer. Follow the directions and be sure to check the reformat box b4 you start. My pearl th1100a is working fine now.
Hope this helps
Q
Posted on May 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca pearl th 1101A
Reset the player by removing and re-installing
of the battery
-Tha Mp3 Doctor
Posted on Jan 09, 2009
SOURCE: RCA TH1611 MP3 Player Wont work
I just fixed my issue. I went to the website listed here and reloaded my software. It erased everything, but I just loaded all my music back on after it reset. It now works and is good to go. http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2241
Posted on Mar 05, 2009
Penrive is detecting but not showing in my computer
when i insert my pendrive in to my pc it will detected by the computer and message your hardware is ready to use appears but when i opens my computer then it not shows on it tell me what can i do.
May 31, 2010 | Pen Drive IVO MP3 Player
My computer wont detect the mp3 and connect
Is the player working normally otherwise?
If so, then try the player in a different USB port on your computer. When plugged in, the display of the Pearl should say that it is connected to a USB device and it will show up automatically as a removable external drive in your windows explorer.
If not, then upgrade the firmware in the unit and the computer will recognize it again. Download the firmware upgradefrom http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and follow all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button the the term "initalizing" replaces "searching",
check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
click the start button to replace the firmware.
After I did this, my pearl started normally, and my computer recognized it again.
Nov 16, 2009 | RCA TH1602 MP3 Player
RCA pearl th1602-a with new battery will not power on. Old battery will power on, but freeze at pearl logo. Player dosn't power on when plugged into USB of computer
Try a firmware recover. Download the firmware update from the RCA website and install the app. Start the updater and connect the player holding the PLAY button until it gets detected.
This is a similar player with the recovery procedure explained:
Oct 28, 2009 | RCA TH1602 MP3 Player
Cant get it to come up on the computer
My only idea is the connector to the player is corrupted or problematic. I would honestly take the player back to the store and get a new one. It seems its not the computer but the player itself. These things happen to many players and many friends of mine have had similar problems with RCA players.
Jun 02, 2009 | RCA Pearl TH1102 MP3 Player
I received a pearl mp3 player from a friend 2 weeks ago
Your questions are too numerous to answer in one post without resorting to my short answer - go to www.rcapearl.com and download the manual, load the installation software, etc.
The "USB Connected" message is normal - the other functions are only usable once the player is DISconnected from the computer.
Feb 21, 2009 | RCA Pearl TH1102 MP3 Player
Syncing files from Media Player to Rca Th1100a
You can view your playlist by opening the device in windows explorer. Start/My Computer/double click corresponding drive letter to your device.
For a copy of the user guide .pdf e-mail a request to
[email protected] & I'll e-mail you a copy.
Feb 02, 2009 | RCA TH1101 MP3 Player
RCA PEARL
First, make sure that your OS is compatible - if you have Vista, you must go to RCA's website and get a new version of the software.
If you have XP:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
Jun 30, 2008 | SanDisk Sansa e260 MP3 Player
Windows media will nt detect my mp3 pearl (RCA
Hope this helps
Q
May 27, 2008 | RCA TH1101 MP3 Player
Rca pearl th1101amp3 player
well it depends on what happened. if you did not do the safely remove hardware from the computer stuff then you might need a new one. the rca pearl is kinda low tech so it has no reset button to wipe its hard drive. i would buy a new one. i need to do the same thing so i feel your pain
Mar 30, 2008 | RCA TH1101 MP3 Player
RCA TH1101 MP3 Player Problems
Remove and reinsert batteries - if that fails, go to RCA website for firmware upgrade - if that fails:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails, it's dead.
-Tha Mp3 Doctor
Jul 04, 2007 | RCA TH1101 MP3 Player
Teac MP-111 MP3 Player Logo
740 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
