Question about Miele Earth S5481 Canister Vacuum Cleaner With SEB 217 Powerhead and SBB 300-3 Parquet Floorbrush
Miele red light
The vacuum will work for a moment, then the red light comes on and the brush wont turn.
Why does my Kenmore intuition vacuum 31810 Red light stay on ?
Here's a couple options
http://www.ehow.com/way_5513470_kenmore-vacuum-troubleshooting.html
http://www.shopyourway.com/questions/1128413
Jul 28, 2014 | Kenmore Intuition 31810 Upright Bagged...
Why won't my Hoover Platinum turn on?
Check and see if there is a reset button for the vacuum head this trips sometime to protect the head motor. Also if the roller heads bind they can snap the belt if it is belt driven. If it is direct drive then I would look for the trip or reset button.
May 14, 2014 | Hoover Platinum Lightweight Upright Vacuum...
My panasonic canister vacuum agitator brush does not spin when on
Possible that you did not get the belt on properly and came off right away.
Apr 13, 2014 | Panasonic MC-CG917 Canister Vacuum Cleaner
My eureka vacuum stopped working.
Need more information. Does the motor run, does the brush turn, does it have suction?
Aug 03, 2013 | Eureka 4870 Boss SmartVac Upright Vacuum -...
My kenmore progressive upright has a loud vibration coming from the agitator brush. Not the belt side, but opposite. Very loud.
The bottom plate may be loose. This can be caused by wear of the mounting clamps or damage caused by an encounter with some indigestible object
Feb 08, 2013 | Kenmore Progressive Upright Vacuum - 31069...
RED CLEAN LIGHT
After cleaning the unit, blue light turns on momentarily then red cleaning light comes back on. Have cleaned and dried unit including the contacts on the end (cleaned with alcohol). Sounds like a common problem, any solution?
Bob
Jun 17, 2008 | Ionic Pro 901P2RIP04 Air Purifier
Miele Earth S5481 Canister Vacuum Cleaner With SEB 217 Powerhead and SBB 300-3 Parquet Floorbrush Logo
32 people viewed this question
Top Miele Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Miele Air Purifier Expert? Answer questions, earn points and help others
