Question about Plumbing
Bonaire evaporative cooler parts
6280807SP
koolbreezes
  • 540 Answers
SOURCE: Is it possible to get a new manual for my Vulcan
Check out this website for manuals.
Posted on Dec 22, 2009
SOURCE: I've lost the manual for my Bonaire VSL75
I think you mean "SLV 75" which is the "Integra" model.
I will post one in the manuals section.
Posted on Dec 30, 2009
  • 37 Answers
SOURCE: Evaporative Cooler Bonaire Profile do you put
Yes, it does require you to pour water into it from the back opening (where the aspen pad is located). I have one myself it works well on days up to 35degrees, the other temperatures higher it just acts as a spot cooler.
Thank you for submitting, and Happy New Year
T.Scott
Posted on Jan 07, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have an evaporative cooler:
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Posted on Jan 01, 2011
  • 1456 Answers
SOURCE: I have a bonaire VSM65
Hello
Check the Room Thermostat Temperature Setting: Set the thermostat to at least 5 degrees below room temperature.
Check that the Room Thermostat is set to "Cool" not "Off" or "Heat". If the thermostat is not set to "cool" it is simply turning off your A/C.
Check that electricity is on for the equipment. Check all switches and controls, including service switches, including outside by the compressor, inside at the air handler, and fuses or circuit breakers in the electrical panel.
For example, condensate spilling into an overflow pan that uses a sensor switch can be enough to shut down your air conditioner. There are several switches and controls, both manual and automatic that can leave an air conditioner or heat pump turned "off" such as a blower compartment door interlock safety switch, an electric motor overload or overheat switches, and a condensate tray spillage detector switch.
Go to AC HEAT PUMP CONTROL AND SWITCHES to be sure you have found and checked every manual or automatic electrical switch on the system. A bad or failed starter capacitor could also be leaving your system shut down, failing to start a blower, fan, or compressor motor.
If the air conditioning system is still not working, or if the A/C system is running but cool air is not coming out of the supply registers you probably need to call a service technician.
THANK YOU FOR VISITING FIXYA
Posted on Jan 30, 2011
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
How to change the filter for vulcan evaporative cooler
I suppose you meant Vulcan Bonaire evaporative cooler.
By filter, I suppose you meant Filter Pads. Here is extract from the Owner's Manual.
Filter Pads: Visually check CELDEK pads for damage or blockage. Hose down pads from both sides to remove any build up of salts, dust and pollen. In dusty areas more regular
cleaning is recommended. Check the water distributor, making sure it is clear and free from blockage. Failure to do so may lead to uneven water distribution and therefore less efficient operation. Do not hose Celdek with high pressure.
Dec 21, 2013 | YouTube Videos
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Kelly
Jan 01, 2011 | Heating & Cooling
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Bonaire Cooling system that stopped working after power failure..
Unplug the unit or turn off the breaker to the unit for at least 30 seconds. If this reset does not work, the electronics may be damaged and need a repair person.
Jan 30, 2009 | Mastercool 67471 Evaporative Cooler Air...
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
