Kenmore 110 28062800
After agitator removal, and 8 screw hub hold down, what holds the basket down? I want to clean under the basket.
JSPCEXPRESS
  • 178 Answers
SOURCE: How do I remove the top of an LG front load washer
No you can't. If you do you have to take the back off etc etc etc... Not worth it.
Posted on Feb 10, 2008
aborcass
  • 2651 Answers
SOURCE: model 80 Sears Kenmore washine(Remove inner basket)
under the agitator youll see a lock nut appox 2-3in, around "locking" the inner basket to the outer basket. although they do sell a spanner wrench to remove this nut, A decent pipewrench and little muscle will get it loose, after that the tub will pull right out. assuming youve taken off the outer tub gasket cover
Posted on Mar 10, 2008
dragonsthatk
  • 547 Answers
SOURCE: coin under the kenmore elite oasis agitator, how do i remove it
remove cap at top of cone unscrew
Posted on Feb 12, 2009
  • 51 Answers
SOURCE: Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Posted on Mar 13, 2009
  • 5 Answers
SOURCE: I've had an Amana Washer model ALW880QAW for about
I couldn't wait for a rely on my posted question on March 6,2009. I was able to ask around to figure out how to clean this up. This Amana washer model has an agitator that is just clipped on. I just got my fingers underneath the agitator and pulled it off. After getting the agitator off, I was able to clean all of the old built up detergent and fabric softner with some old fashion scrubbing. Then I used some CLR to get what ever I missed. I pushed the agitator back until it clicked back into place and ran one washing cylce to clean things up.....Works great....No more old clumpy stuff showing up in the wash....
Kenmore 20802990 makes loud sound when spinning
Could be the clutch slipping if sound is like brakes if it's a rumble the hub that holds basket may have broke describe sound better
Apr 30, 2016 | Kenmore Washing Machines
Getting an OL problem code
1. Unplug the power cord
2. Lift the top of the washer up, to do this there are 2 latches in the seams between the top and the bottom sections. These latches are about 6 1/2 inches from the right side and left side of the washer. You need to insert a small screwdriver (be careful not to scratch the paint) and push the latch while lifting the top section.
3. The top will actually fold back leaving the inner tube fully exposed. Support the glass lid so it doesn't get damaged because it is very heavy and will fall open when you flip the top back.
4. Remove the plastic top of the tub. There is one hose connected at the back and there are several snaps around the outter edge that hold it on. Remove the hose and unsnap the snaps and set it aside.
5. Remove the cap covering the very center of the agitator. It is just snapped in place and can be pryed off with a small screwdriver.
6. Remove the center screw under the cap.
7. Remove the agitator, you need to lift it evenly and might have to work your way around by pulling on one of the three fins and then the next and so on. I also had luck using a small pair of needle nose pliers and grabing a small lip inside the area where the screw was and pulling from there.
8. Remove the 6 phillips screws in the middle holding the plastic top gear in place. Be very careful you don't drop one of the screws because it can fall through the slots in the basket and be lost below.
9. Remove the plastic top gear.
10. Pull the plastic lower gear off of the splined shaft. It should pull right off.
11. Now you need to pull the basket up and off of the shaft. This is where you might have problems because the basket might be corroded to the shaft. If you can grab the basket on both sides under the outter lip and pull upward it might pull up. If not, then you will have to figure out a way to get it off.
12. Once the basket is off you will notice there is liquid inside of it. That is factory sealed in there so do not worry about that, it is normal.
13. With the basket is off you will be able to see that the shaft is probably corroded and the inside bearing on the basket is corroded. Clean these both off very good and check to see if the basket can easily go back on the shaft and slide up and down without getting stuck. I had to sand and file the shaft a little bit to get it totally cleaned up. The inned bearing of the basket is plastic so it is pretty easy to clean with light sanding.
14. Reassemble in the reverse order and your done. Check to make sure the basket can easily float now by pulling up on it from the top inside lips.
Dec 03, 2012 | Kenmore Dryers
Kenmore 92283800 agitates sometimes if not to many clothes are in the washer...but I can hold the agitator and it stops completely
Welcome to FixYa.
Based on your description, the problem is likely worn agitator dogs/gears. The new dogs alone part # 80040 or what I'd recommend, part # 285751 as a kit with new hub too.
These are common and available at most brick & mortar parts depot's as well as on-line vendor's such as "repairclinic.com" or "searspartsdirect.com" to name a couple.
You`ll need to remove the top of the agitator to replace them.
To remove the top cover of the agitator, it should lift off by prying up gently with a flat screwdriver or puddy knife.
Under this cap there actually is a screw/fastener,( bolt ) it just may or may not look anything like a typical screw. It could be a plastic piece with a square center and with the aid of a large flat screwdriver inserted in this location pressed into one of the corner`s in the square center (as to hold it still or turn it,
I usually hold it still while turning the agitator) at the same time as holding the bottom of the agitator, turn it counter-clockwise and it will come loose. It may be the bolt style and in that case just remove the bolt and lift it out.
On Kenmore full size washer`s built by whirlpool there are several types, ones with a 7/16", 1/2" or 9/16" bolt holding it in place, and the type I described.
This is a link to a helpful "how to" video...it may have slight differences to your washer, but essentially the same.
http://www.youtube.com/watch?v=0GQh8JLqVv8&feature=related
Thank`s for visiting FixYa. Good luck and let me know if I can assist you further.
Regards,
Macmarkus :)
Dec 18, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series does not agitate.
Hello, Welcome to FixYa.
The model and serial number tag will be under the lid at the back of the "lip/shroud" as you look from the front.
Based on your description, the problem is likely worn agitator dogs/gears. The new dogs alone part # 80040 or what I'd recommend, part # 285751 as a kit with new hub too. These are common and availble at most brick & mortar parts depot's as well as on-line vendor's.
Under this cap there actually is a screw/fastener,( bolt ) it just may or may not look anything like a typical screw. It could be a plastic piece with a square center and with the aid of a large flat screwdriver inserted in this location pressed into one of the corner`s in the square center (as to hold it still or turn it, I usually hold it still while turning the agitator) at the same time as holding the bottom of the agitator, turn it counter-clockwise and it will come loose. It may be the bolt style and in that case just remove the bolt and lift it out.
On Kenmore full size washer`s built by whirlpool there are one 2 types, ones with a 7/16" bolt holding it in place, and the type I described.
macmarkus :)
Jul 15, 2010 | Kenmore Washing Machines
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Nov 18, 2009 | Admiral AW22 Top Load Washer
At the end of the spin cycle, my Kenmore Washing Machine makes a grinding noise like an out of balance brake drum. What could be the problem
If your washer model number starts with 110. it's a whirlpool washer. Whirlpool use a spin tube with two notches in it. There is a block assembly that holds the inner basket down on to the spin tube. This can be accessed by removing the top of the agitator and take out the 7/16 screw. Lift the agitator to expose the top of the spin tube. The tube is stripped on top where the basket sits. When the washer stops spinning, the inner basket keeps moving. That is the noise you hear. Replace the spin tube and possibly the block.
Oct 03, 2009 | Washing Machines
Model 23832 Spin cycle doesn't spin
I believe this is the direct drive model. Your clutch is slipping. There is a quick easy fix available that I have used in the past. Remove cabinet from washer. Make sure you know the easy way to do this... 2 screws on top back of washer and 2 holding control panel. cabinet tips toward from of unit and off. Real easy... Remove wire harness from motor under basket. Remove 3 screws holding motor to basket. Remove agitator inside basket. 1 screw holds it in place. Remove entire motor and shaft from unit. Clutch is attached to shaft on top of motor. Pinch spring to remove clean everything with alcohol. Insert #10 washer between cup and spring to give a little more tension. Replace and viola.... all should work well.
Jul 10, 2009 | Kenmore 23822 Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
