Question about Sharp 27N-S50 27" TV
Missing Cable Connector
I have a Sharp 27N-S50 and it is missing the cable (f-connector) connector on the back. I removed the cabinet and the shields where it enters the chassis, but don't see where I should connect the generic replacement part. I am an electronic technician (motorola) so I am comfortable with doing repairs. It appears to me the internal connection may have been a compression or some such fitment rather than being soldered. Any suggestions? Thanks,
  • jetdawg Aug 10, 2007
    To be a little more clear, what I need to know is where on the tuner does the center pin of the female f connector connect to the tuner. Hope this clarifies things. Thanks again.
  • jetdawg Aug 27, 2007
    Thanks for help Mike, I finally got around to this project this past weekend and it is now up and running great!
    Thanks Again,
    Jetdawg
  • 398 Answers
After you remove the tuner from the main board and remove the 2 covers from the tuner, straighten the metal side of the tuner where the hole is for the F connector. If you look at the PC board inside the tuner, there is a small hole in the board directly under the hole in the metal for the F connector. Usually there is a small piece of the old F connector's center pin still soldered in that hole. If it is there, unsolder it and throw it away. The new F connector will be soldered in place over the hole in the side and a small jumper wire soldered from the center pin of the new F connector to the little hole in the PC board directly under it. Be careful when soldering on the tuner's PC board because the parts are extremely small and close together, and lost SM parts and solder bridges are possible. Be sure none of the coils in that area have been squashed over, which is what I usually see when the costomer sticks something in the hole left in the tuner. If the coils are squashed, you can straighten them with a small pair of tweezers or remove them and rewind then around the proper size drill bit. Let me know how you make out.
Posted on Aug 11, 2007
Color is off
try to reconnect all connector on cable box and your cable connection on your TV.
Oct 28, 2012 | Sharp LC42SB48UT 42 in. LCD TV
Sharp zq190 personal organiser has bits of lines missing on the display,i have 2 of these both same problem
Try removing battery and putting it back, even if this wont probably ficx it
From description it looks like the LCD display ribbon cable and connector inside the problem had moved or is out from place, the phone must be taken apart to fix this.
Oct 03, 2008 | Computers & Internet
How to hook up headphones to a sharp 27ns100
It looks like your TV has stereo AUDIO OUT jacks on the rear panel (L and R) which you can use to connect headphones. Go to a local Radio Shack or other electronics retailer and ask for help with the required adapter cable and connectors. They should be able to direct you to the product(s) as Radio Shack has these simple adapters and they should cost very little. All you need is a simple RCA cable with the white and red plugs for the TV side and depending on your headphones, either a 3.5mm or larger connector for hookup on the headphone side. They also sell extension cables so you can move away from the TV more. Don't let them sell you anything fancy or expensive as this is really simple.
Mar 14, 2011 | Sharp 27N-S100 27" TV
Sharp 27N S50 need universal remote code
You didn't mention the brand of your remote. Anyway try the code below.
SHARP Codes: 004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Try the 3-digit code at a time.
Hope it may help you.
Have a nice day!
JDVillanueva
Feb 04, 2011 | Sharp 27N-S50 27" TV
The antenna/cable connector looks broken. can this be replaced?
Hello
In most models of Sharp Telivisions,antena socket is an integrated part of the tuner itself and cannot be replaced with an other one. There is only one way and is to replace the tuner itself.
If you don't mind of style, you can solder two wires, one from the center pole of the antenna socket, and other from it outer rim, and take it out and connect to an external ariel socket [can be bought from electronic sparepart shop as a seperate socket] , to whcih you can connect your ariel pin. It will look a little dull, but you can face the probelm, without replacing the tuner. When making these connections, use sigle cored shield wire. It center wire must connect to the center pole of the broken tuner socket. OK.
Dec 09, 2010 | Sharp 27N-S300 TV
I have a 07 f150 4.6L V8 and I need to replace the Bank 1 sensor 1 oxygen sensor but cant figure out which sensor it is since there are 4 sensors. Where can I find a picture of the location?
Heated Oxygen Sensor (HO2S)- The Bank 1 Sensor 1 tells me that it's an upstream O2 sensor. The larger the number the further down the line of the exhaust it is. Removal & Installation 4.2L Engine ford-04-42-2750.gif
To Remove:
  1. Raise and safely support vehicle.
  2. Disconnect battery ground cable.
  3. Detach electrical connector from right inner fender splash shield (if necessary).
  4. Remove right inner fender splash shield (if necessary).
  5. Disconnect heated oxygen sensor electrical connector.
  6. Remove heated oxygen sensor.
To Install:
  1. Apply anti-seize lubricant to heated oxygen sensor threads.
  2. Install heated oxygen sensor. Torque to: 34 ft-lbs (46 Nm)
  3. Connect heated oxygen sensor electrical connector.
  4. Install right inner fender splash shield (if necessary).
  5. Attach electrical connector to right inner fender splash shield (if necessary).
  6. Connect battery ground cable.
  7. Lower vehicle.
To Remove:
  3. Disconnect heated oxygen sensor electrical connector.
  4. Remove heated oxygen sensor.
To Install:
  4. Connect battery ground cable.
  5. Lower vehicle.
Nov 07, 2010 | Ford F-150 Cars & Trucks
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
KK266 mother board (IWill) need a wiring diagram, usb is not being identified
Antec doesn't make mother boards, they make enclosures. The standard USB connection on the board is a 2x5 pin connector, with 1 pin missing. The end that has the missing pin, is the end that the cable shield is attached to.
Mar 24, 2010 | Antec Computers & Internet
Cable hookup broken
Sometimes you can replace the rf connector by resoldering it with a replacement rf. You will have to remove the tuner to do this. The big question is did you crack the tuner board or the board the tuner is connected to. You will really have to examine these. In most of my cases a successful replacement rf connector will fix.
Aug 24, 2009 | Sharp 27N-S300 TV
Cable female adaptor is missing
The small metal box is the tuner. The tuner has to be removed to replace the broken off RF connector. The connector has to be soldered to the tuner housing (metal box) and the leg of the connector has to be soldered to the circuit board, board has to be checked for cracks or if it is broken. If board is damaged the tuner will have to be replaced, if its available.
Aug 17, 2009 | Emerson EWF2703 27" TV
Sharp 27N-S50 27" TV Logo
370 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
