Question about Directed Transponder Anti-Theft Bypass 556UW Transponder Anti-Theft
2001 mercedes e320 how to bypass anti theft - Directed Transponder Anti-Theft Bypass 556UW Transponder Anti-Theft
2 Suggested Answers
  • 5 Answers
SOURCE: 2001 Chevy Astro Van Anti Theft Radio System
You can remove the antenna plug from back of radio and then input the password.
Posted on Sep 18, 2012
How to bypass a merceds-benz sensors key to start the engine
i dont think there is a safe way to do this have to give mercedes a ring and get there advice, dear i know but what can you do
May 12, 2014 | Mercedes-Benz E-Class Cars & Trucks
E320 key won't start 1st try
It is a key issue most likely, try unlocking the car and taking a little more time to insert key into igniton than you normally do to see if that works. It can be a coding/timing issue in the anti-theft logic and most times replacing the key is all that is needed. otherwise it is the EIS acronym for electronic ignition switch which is a major control unit for the starting and anti-theft system.
May 17, 2012 | 2005 Mercedes-Benz E320 Sedan
1995 E320 battery drained dead,
The anti-theft system is likely the problem. It needs to be reset.
Apr 22, 2012 | 1995 Mercedes-Benz E-Class
2004 e320 just replaced the front and rear brakes and now I get the ESP malfunction visit shop.
MERCEDES BENZ DEALERSHIP HAS TO REPROGRAM THE ANTI LOCK BRAKE SYSTEM AND ELECTRONIC STABILITY CONTROL SYSTEM.IF YOU DISCONNECT BRAKE PAD WEAR SENSORS WHEN REPLACING BRAKE PADS. THE ABS BRAKES AND ESP SYSTEM HAS TO BE RESET TO TURN OFF ESP LIGHT.
Aug 14, 2011 | 2001 Mercedes-Benz C-Class
Have a 2001 sunfire , replaced complete steering colum will not start,, anti theft system cuts in.can you help
NEED TO RE FLASH ANTI THEFT . TRY THIS LEAVE KEY ON FOR 10 MIN DONT START.CLCLE KEY OFF THEN BACK ON DO NOT TRY TO START. WAIT 10 MORE MIN , REPEAT PROCESS AGAIN, THEN TRY START....
Apr 14, 2011 | 2001 Pontiac Sunfire
1995 Mercedes Benz E320 Wagon, How do I reset the Anti theft so I can start the car. My daughter is stranded right now please help
1. Lock doors via key on Driver's door.2. Disconnect battery.3. Wait a couple minutes to let remaining voltage leak out of system.4. Reconnect battery.5. Unlock doors via key on Driver's door.
Oct 30, 2009 | Mercedes-Benz E320 Cars & Trucks
Wont start do to theft system
You can not, the anti-theft circuit can not be bypassed. Your forced to bring it to the dealer.
May 24, 2009 | 2001 Ford Windstar
Car will not start
find the fuse for the alarm and pull it out then try to start it.
Apr 30, 2009 | 1994 Mercedes-Benz E-Class
I have a R reg mercedes E320, the other day i got in to find that the ignition key will not turn, it doesnt seem to power up the ignition barrel?? ive stripped the barrel and if you insert the key and take...
Most likely there you have a security system VAT (Vehicle Anti-Theft) module. If you try to bypass this the car will not start. Have a mechanic or yourself get to the main wiring harness to the ignition in the steering column under the dash, unplug it and use another ignition with a key in it to learn the security system code first before trying to start it.
Jul 15, 2008 | 2001 Mercedes-Benz C-Class
Directed Transponder Anti-Theft Bypass 556UW Transponder Anti-Theft Logo
18 people viewed this question
Top Directed GPS Experts
Are you a Directed GPS Expert? Answer questions, earn points and help others
