Question about Colubris Networks (CN3200) Integrated 802.11a, 802.11g/b
Colubris default networks password - Colubris Networks (CN3200) Integrated 802.11a, 802.11g/b
Forgotten password for wifi network
Which operating system ??
Your wireless Internet password is the encrypted security pass phrase that was set up when you installed your wireless router.
Your router allows you to access the Internet.
If you have access to more than one wireless network, you may need to remember multiple passwords.
If you happen to forget one password, you have two options: reset your password or locate the current password.
Windows 7 allows you to view the security characters of all your wireless network passwords.
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
or
Reset My WiFi Password
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser.
Enter the default address of your router.
The default address is listed in your user manual or on the product website.
Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings. Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
How To Reset Your Router's Password
http://www.lostintechnology.com/how-to/how-to-reset-your-routers-password
Jan 06, 2014 | Computers & Internet
Forgot password and user name and i never had put a emial
default password is password
Looking for the NETGEAR WNR1000 default password?
You probably have little reason to access your router on a regular basis so don't feel too bad
f you've forgotten the WNR1000 default password.
However, when you're troubleshooting a network problem and need to get in to the device,
the WNR1000 default password suddenly becomes very important.
For most versions of the NETGEAR WNR1000, the default password is password. As with most passwords,
the WNR1000 default password is case sensitive
Be sure to change the default router password on your WNR1000 to something more secure as soon as you're in.
Then use a free password manager so you'll never forget your new WNR1000 password
hope this helps
Aug 06, 2012 | NetGear WNR1000 RangeMax 150 Wireless...
WIRELESS GATEWAY
How to View or Change Your Wireless Network Password
Symptoms:
You have lost or forgotten the password to your wireless network
You have lost or forgotten the password for the router, access point or other network device
You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Launch your Internet browser and type http://www.routerlogin.net in or http://192.168.1.1 or http://192.168.0.1 the address field for your browser. Enter the router's username and password.
The default username is admin, the default password is password.
From the left-hand navigation menu of the Router administration interface, select Set Up > Wireless Settings
Note: On some routers this option will be under BASIC > Wireless.
From the center screen, you find the current wireless security settings under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Read more about Securing your Wireless Network.
If you cannot log into your router:
- If you were routed to the NETGEAR website or getting the "Page cannot be displayed" message when trying to login to router, make sure you are connected to the NETGEAR router. Check your wired connection and make sure cable is securely plugged in and LED is on. If wireless adapter is on, make sure you are NOT connected on a different wireless network.
- Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default access information to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Secure Your Wireless Network: WPA/WPA2 (Recommended)
Reset and Restore a NETGEAR device to Factory Default Settings
Default Password for NETGEAR devices
Jul 19, 2012 | Gateway Computers & Internet
Need to hard reset westell 7500 modem to factory defaults..cust chngd admin password and can't remember what they chngd it to and i need to get into modem
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Nov 05, 2011 | Westell Wirespeed VersaLink...
I lost my net gear n150 cd and i want to change my password..
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Sep 10, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
Need to find out password or how to reset a new password
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
dont forget to vote hope this helps
Feb 05, 2011 | NetGear WGR614 Wireless Router
I need the software and drivers
Contact us for advanced configuration and tech support for these, we have 8 years experience with Colubris/HP and have installed, managed and operated over 2000 hotspots with this device.
I looked at www.diplodrivers.com and could not find currnet colubris / HP firmware...
Regards
Murray
http://wireless.deepcoolclear.com/
Dec 22, 2010 | HP ProCurve MSM313 WW (J9350A)
Default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Jun 22, 2009 | Computers & Internet
Iam not remembre the username and passworld i want username and passworld preicipal i have the same problem my colubris cn3200 WLAN Access Point/controller. im in a computer course and we where given it...
To reset to factory you have to hold reset button until ALL THREE LIGHTS FLASH 3 TIMES!!! Then you can access it through web portal at 192.168.1.1 with admin/admin. (Make sure you set a static IP on your computer 192.168.1.2 and gateway 192.168.1.1 and use a crossover cable). After factory reset the power light should flash rapidly letting you know its in controlled mode. Once you log in you can switch it to autonomous mode.
Feb 02, 2009 | Colubris Networks (CN3200) Integrated...
Colubris Networks (CN3200) Integrated 802.11a, 802.11g/b Logo
59 people viewed this question
Top Colubris Networks Computers & Internet Experts
David Payne
David Payne
Are you a Colubris Networks Computer and Internet Expert? Answer questions, earn points and help others
