Aoc 152v lcd monitor - Computers & Internet
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor - Manuel
I assume you only found the 4 mount screws in the back... You also need to take off the front silver edging - it pops off with some negotiating, but if you find the right spots and don't pry hard it will come off clean without too much difficulty. Then take out the screws that hold the screen inside and it should drop out.
webdevil
  • 43 Answers
SOURCE: aoc LCD monitor problem
If some of the pins inside the monitor cable are bent or broken you can losr primary colors and cause this. Check them. If they seem OK try reseating both ends of the cable. If no go, then try the monitor of a differnt computer to see wether its the videocard or the monitor thats defective.
Posted on Jan 06, 2009
budmrtn
  • 11361 Answers
SOURCE: AOC LCD MONITOR
The cable from the Monitor USB input to PC USB output is good? Check to see if you do have 5vdc on pin 1 of the USB connector. Your monitor is basically a powered USB hub when it is connected to PC through a USB cable.
Posted on Jan 20, 2010
budmrtn
  • 11361 Answers
SOURCE: My AOC 2019Sw1 - 20" LCD monitor is not working.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 01, 2011
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Feb 05, 2016 | AOC 917Sw 19" LCD Monitor
My problem is how to open OSD LOKED OF AOC E 2237Fwh 21 inch LCD monitor
MY AOC LED 2237FWH SHOW OSD KOCKED SO HOW TO OPEN THIS? PLS SAY ME
Sep 29, 2012 | AOC e2237Fwh 21 inch LCD Monitor
I have a AOC L520 MONITOR and the touch screen doesnot work.Were I can found the software?
Here, from the manufacturer's website.
ftp://ftp.aoc-europe.com/Drivers/LCD-monitors/LM520&LM520A.zip
Rulan
Jun 16, 2011 | AOC LM 520 15" LCD Monitor
How do u get to the menu on my aoc lcd monitor
hi
Depending on the brand and model of your monitor, there may be extra features that require special troubleshooting tips, or there may even be alternate ways of troubleshooting basic problems. For this reason, it is important to keep your user manual.
If you have come across an issue with your LCD monitor that cannot be corrected through the basic settings, you should consult the user manual to determine troubleshooting solutions for your specific monitor.
For example, The AOC 175F LCD monitor features a 90-degree rotating display, which, in order to rotate correctly within Windows XP, must have AOC's third-party software installed. This is not something required of all LCD monitors, as not all LCD monitors offer a rotating display.
If the troubleshooting section of your user manual still does not solve the problem, it may be necessary to contact the manufacturer's support team (via phone or web) to discuss what is wrong with your monitor
Jun 26, 2010 | AOC LM729 17" LCD Monitor
AOC LCD MONITOR
Jan 20, 2010 | AOC 22" Widescreen LCD Monitor
I need a manual for a 22" AOC monitor
Suggest you go to AOC Support, Downloads>Manuals, and type the exact model of AOC monitor that you have.
Download the User Manual.
For example:
http://us.aoc.com/support/downloads
Product Category:
Left-click on the blue down arrow, to the right of this box.
Left-click on LCD Monitors
Model Number:
Left-click on the blue down arrow to the right of this box.
Scroll down, and left-click on the model number of your AOC LCD monitor.
After you have done this, a drop down menu will appear.
Where it states your monitor's model number, and the word - MANUAL, go to the right, and click on the white - Download.
The User Manual is in PDF file form. Give it a few seconds to download.
Jan 03, 2010 | Computers & Internet
I can't find aoc 210s drivers. Where can i get
Please follow the below link
http://www.voiceofchinese.com/techs/aoc-210s-2210s-lcd-monitor-drivers-for-windows-xp-vista
Please download the drivers from below link
http://www.voiceofchinese.com/files/AOC-210s-2210s-LCD-monitor-driver.7z
I believe your problem will be solved
Sep 04, 2009 | Computers & Internet
Aoc LCD monitor problem
Jan 06, 2009 | AOC LM729 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
