Question about Sunpentown WA-9000E Air Conditioner
Manual how often needed to clean/change filter?
My nissan primera goes off at slow running. 2000model, manual,1.8 engine.
clean out the idle the idle valve on the inlet. remove and clean the unit. also replace the air filter and clean the maf/map sensor before starting engine after air filter changed as dirt from the air filter can coat the maf sensor and this will give a wrong reading to the ecu.
May 18, 2018 | Nissan Cars & Trucks
How to service a hyundi van h-1
You need a workshop manual to do the job properly. There are different items to service depending on the mileage - for example, a small service would usually entail cleaning the air filter and checking the fluid levels - engine oil, radiator water, brake and clutch fluid etc. Then check the tyres for wear and make sure all lights work OK.
A medium service would be to clean the air filter, or fit new one depending on driving conditions - you need to change this filter more often in dusty conditions.
Also, drain engine oil and refill and change spark plugs. Check plug wiring for cracks or breaks and do all in minor (small) service.
A major service would include all the above, but you now need to change the oil filter, fuel filter and the air filter, if necessary (oil and fuel filters are necessary).
Also, remove wheels and check condition of brake linings, check tyres for wear caused by misalignment and check play on wheel bearings.
These checks are not specific to your vehicle, and is just an overall guide. Your workshop manual may specify other areas. If in doubt, see your dealer, they have all the experts on hand.
Nov 26, 2016 | Cars & Trucks
How to change filters on lg dishwasher
Your dishwasher may have a filter located near the bottom or under the lower spray arm. This filter should be inspected and cleaned regularly. Follow your dishwasher owner's manual for specific instructions about how to properly remove and clean this filter, if equipped. If there are any holes or other damage to the filter, you'll need to replace it immediately to protect the dishwasher's pump and motor seals from damage.
Jul 20, 2014 | LG Dishwashers
Shows change filter where is it located?
Hello Ann, this is JK. I understand that you are looking for the location of the filter in a dehumidifier. Generally, you will need to remove the bucket to be able to reach under to remove the filter. Please refer to your owner's manual for more detailed care and cleaning instructions. Hope this helps!
Apr 07, 2014 | Frigidaire Dehumidifiers
2005 Kawasaki Vulcan 1600 Nomad how to clean the fuel filter
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Fuel Filter Replacement
Motorcycle repair How To Change Fuel Filter
Kawasaki VULCAN 1600 NOMAD Service Manual
OEM Parts for Kawasaki
2005 Kawasaki Vulcan 1600 Nomad Owner Manual
Jan 27, 2014 | 2005 kawasaki Vulcan 1600 Nomad
2005 Honda CB 250 Nighthawk oil and filter change
Hi, Waesch for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
CB250 beginner oil change filter clean
Servicing CB250 Honda 1995 NightHawk
Honda CB250 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB250 Nighthawk Owner Manual
Jul 06, 2011 | 2005 Honda CB 250 Nighthawk
How do you change a oil filter on a 1971 Honda CL 350 motorcycle?
You don't really "change" the filter. You just clean it. There is a screen filter on the bottom of the oil pump that serves to do a basic filter of the oil going into the oil pump. The real "filter is a centrifugal filter on the right end of the crankshaft. The spinning filter forces the heavy dirt particles to the inner rim of the filter where they build up to a somewhat solid mass. A screw driver pushed into the mass will break the dirt up and when most of the dirt mass is removed, a can of carb cleaner can finish the job. Only minor dis-assembly of the filter is needed to clean it. There is no need to actually remove the filter from the crankshaft.
You can download a free factory service manual at www.carlsalter.com/motorcycle-manuals.asp Please rate my answer. Thanks.
Feb 09, 2010 | 1972 Honda CB 350 F0
Vacuum is about 4 years old does not pick up well
Have you ever replaced the belt? That is most likely the reason that it is not picking up like it used to. You are actually supposed to change the belt yearly. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belts and Manual
Dec 31, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Need owners manual
Hi, try here:
http://safemanuals.com/user-guide-instructions-owner-manual/DYSON/DC07-_E
I doubt you've ruined it, just clean/change it asap!!
Hope that helps.
Dec 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Sunpentown WA-9000E Air Conditioner Logo
37 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
