Toshiba L650 problems with hhd/states no bootable device
It is running the bios ok,my computer im on has no cd reader/writer,so im stuck with usb, files are on external hard drives along with too much stuff...wont,boot properly,wants to run ethernet-i use wifi.. cant return to factory,doesnt want to load drivers...is there a specific driver/or install im missing
Nitrotrike
  • 589 Answers
SOURCE: GMA 4082n device driver not working properly code 39
Please post the exact model of the notebook, as there are several models in the A60 series.
Posted on Jan 09, 2008
SOURCE: Toshiba 2.0 external hard drive
mrtunink,
Yellow ! simbol show in the usb devices means your usb driver may be corrupt so OS can't recognised the usb devices, u have to reinstall the driver like that way,
At first right click on my computer icon- then select propertices- then "hardware" - then click on devices manager buttons- then select ur devices and right click on it and click propertices then u finds reinstalls button under its propertices click on it and select install software automatically (recomanded) and click on ok. then windows scarch its driver automatically and install it.
Posted on Jul 03, 2008
hardkiss69
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
pankaj_dic
  • 1252 Answers
check whether the device is detecting properly on bios or not
Posted on Oct 01, 2008
SOURCE: dvd writer driver missing
Go to Vista tech support. Sometimes if you used a cd/dvd that wasn't compatible with the system, vista creates filters. If you remove the high and low filters, it might help. Vista tech support has a page on how to do this. It worked for me after months of trying everything else.
Posted on Dec 18, 2008
How do i fi no bootable devices on my Toshiba Satellite laptop
.- what kind of toshiba you have?
Normally, if you have a bootable USB stick (and your BIOS recognize this kind of device) insert it and give it a try.
Or, insert a bootable CD/DVD into your CD/DVD tray and boot.
Once the operating system was booted from any of those devices, proceed with installation of the operating system on your HDD. Good Luck!
Jul 20, 2014 | Computers & Internet
Bios does not see cd-rom but dos does, can't boot cd
Sounds like a hardware issue. Try downloading UBUNTU as an alternative to Windows. If you still need windows Install virtual box for UBUNTU and run it that way.
Virtual Box: https://www.virtualbox.org/wiki/Linux_Downloads
You probably have tried holding "F12" during bootup. This will give you the option to start from the CD.
If you suspect it's a BIOS issue try flashing the BIOS. You can do this by going to the PC manufacturer website and searching for support- Drivers and downloads.
If your BIOS supports USB boot you can try to update the BIOS that way. Then going back and configuring it for CD boot.
You can also try to create an ISO image of Windows and install it via USB.
Mar 10, 2012 | Computers & Internet
My dvd/ cd writer can not read any type of cd and now I can not reboot my laptop.
You should make a bootable Flash drive.
You will just click on bellow the link and follow all the step.
http://komku.blogspot.com/2008/11/install-windows-xp-using-usb-flash-disk.html
After making the bootable pen drive go to bios setup>Restart>press F2/F10/Dell
Boot from usb.
There are many type of bios setting.
Follow these .
http://www.computerhope.com/help/phoenix.htm
http://www.pcbuyerbeware.co.uk/BIOS.htm
and also set you HDD piority ,Now note it ,Usb drive will be 1st Hdd drive(usb pendrive)
Hope it will solve your problem.You can also repair or change the cd/dvd writer through folloing steep.
Or can do it from this link.http://komku.blogspot.com/2009/09/wintoflash-guide-install-windows-xp.html
Hope it will help you.
Jan 07, 2011 | HP Computers & Internet
I hav a dell laptop (latitude D810)..when i switch it on it displays NTLDR is missing..also my CD drive is not working..please suggest me if i can do something using USB port,,,,
Yes you can make a bootable pen drive using some other pc which is having both usb and cd writer working. Simply copy the complete files of your os file to that pen drive or external hdd and change the bios settings such that the first boot option shall be usb device and search other bootable device should be enabled.
Aug 27, 2010 | Computers & Internet
How i can boot from a cd to install os
1. Turn on your computer
2. press the proper key in order to enter bios setup while black screen in progress. this key may f2 or f8
3. investigate the boot device order
4. set the cdrom as #1
5. press f10 key to save and exit.
6. put a bootable installation CD/DVD into the cd/DVD reader's tray.
7. cut off the po-wer
9. power on the computer
if everything ok, the computer will check the cdrom device to boot and start booting from cd.
Aug 18, 2010 | Toshiba Satellite 2060CDS Notebook
My sata Dvd Writer 22xsuper-writermaster SH-223 is not bootable
You should set the First boot device to DVD/CD rom from your Bios , thats it..Nothing other than that , whether it may be SATA or IDE or even the version of Bios doesnt matter..
Rnj VINOD KUMAR
Sep 12, 2009 | Sony Computers & Internet
DELL Poweredge 2600
The Dell original standard CD drive shipped with the PE2600 is incapable of 'understanding' the latest generation of bootable CD's (no matter what the BIOS says).
As far as I can tell, it's not fixable in the firmware ..
However you can swap it out for a more modern drive - such as the TS-L462C (which is a plug in replacement combined DVD reader / CD reader/writer - and Dell post the required drivers on their PE 2600 web pages, so I assume it must be a 'supported' solution)
Jan 18, 2009 | Dell PowerEdge 2600 Server
Bios entry
solution #1
you can purchase a $15 usb floppy drive and use the disk.
Solution#2
Create a bootable cd of the disk on another computer.
solution#3
Download this file and create a cd per the instructions.
http://www.softpedia.com/get/Security/Decrypting-Decoding/CmosPwd.shtml
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | Computers & Internet
Bootable CDs are not working with my new DVD writer
Try to update your BIOS first, then call me in the morning.
Nov 26, 2007 | Acer TravelMate 2303LCi Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
