Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Where are the grease fittings on a yth2348? - Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
How can I remove the pressed in grease fitting on a 1930 Ford
Grab it with a good set of vice grips and work it out, I have had grease fittings that won't take grease and some of them the parts had to be removed and the lube hole cleaned out. you can also buy a grease injector that is a hollow barrel with a plunger that fits down in it and you pull out the plunger fill the barrel with grease install the plunger, place the injector on the grease fitting and hit the plunger with a good size hammer
Jan 12, 2016 | Ford Cars & Trucks
How to fit a starter motor on a Husqvarna rider pro 15 ?
when your fiting it to the motor you will need turm the motor with your hand to get it to seat for the bolts to fit in
Jul 26, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a husqvarna LTH 126 ride on mower ,do i have to check oil in gearbox and is there more than four grease nipples
Hydro units are pretty well sealed, if there is no leakage under the machine when left, then leave it alone.
Feb 26, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Hi I have the YTH2348, the problem i'm having is i'm getting a bearing sounding squeal when i have the blade clutch engaged. I noticed before it starts to squeal I'll hear a like loud click and...
if its an elect pto then it sounds like its in the workings of the pto pully
also if its a manual lever that you move to engage the belt, it could be the pully that tightens up the belt and turns the blades, most of the pullies are greaseless and prettymuch throw away
Jul 25, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Looking for a oil filter # for a fram oil filter to fit a husqvarana yth2348 mower. thank mike
I don't think fram has a filter for it, but you can get the filter at NAPA, Lowes, Home Depot, O'Riley's, Sears, or any small engine shop. According to Sears Parts website the model # that you gave has a Briggs and Stratton model # 445577-0284-e1 engine; however a B & S or Kohler engine manufacturer's filter with fit your engine. They are interchangeable. The B & S part number is 696854 or 120485.
Hope this helps. Please vote yes if it did. Thanks
Nov 01, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Where are the grease fittings ?
Manufacturers generally removed grease fitting from suspension part back in the 80's. Some put a removable plug in the ball joints, tie rod ends, etc, which could be removed and grease fittings installed in their place, but most have sealed and permanently greased. In other words you can not lubricate any fittings. If parts go bad, the replacement suspension parts generally have grease fittings.
Aug 10, 2010 | 2000 Mercury Grand Marquis
I have a husqvarna riding mover it will start but you put in gear it wont move!
It is probably the rusty disengage valve lever on the top of the transaxle. Spray with rust eater and lube with grease. You can get to it be removing the hitch plate.
Sep 26, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
GREASE FITTINGS
there are either grease fittings or plugs where they go, the fittings will be in the ball joints and the tie rod ends. should grease about every 6,000 miles or so, if u go through water allot more often
Jan 15, 2009 | 2008 Hummer H3
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
