Question about Gigabyte GA-G41M-ES2L Motherboard
Does a GA-G41M-ES2L Motherboard support Asus GTX650 graphic card?
  • 5,660 Answers
5 Suggested Answers
ausimailbox
  • 75 Answers
SOURCE: Installed new motherboard (Gigabyte GA-G41M-ES2L),
hello tami_hennacy
unfortunately the wiring color for computer cases are not standard. so blue and white does not mean much. you need to look at the connection on the tip of the wire to see if it is labeled so you can locate the corresponding connection point on the mother board. Gigabyte motherboards have a very good step by step discretion of all connections.
if it is not labeled then you need to oped the case front panel and see what the other end of this pair of wires is connected to.
hopefully this has helped
good luck
Posted on Feb 04, 2011
SuperTech-11
  • 1591 Answers
SOURCE: can any one tell me
You'll have to give me a price range
At just under $5000 (yes, five thousand) dollars, you can get the
PNY VCQ6000-PB Quadro 6000 Fermi Graphics Card - 6GB, GDDR5, PCI-Express 2.0 (x16), Dual-Link DVI, Dual DisplayPort, Stereo, DirectX 11
The PNY VCQ6000-PB Quadro 6000 Fermi Graphics Card is the world's first 6 GB NVIDIA Professional Graphics Solution.
Posted on Feb 28, 2011
  • 5 Answers
SOURCE: where would i get GA-G41M-ES2L driver
http://www.gigabyte.com/products/product-page.aspx?pid=3500#dl
In the Downloads section, select your OS, then download.
Posted on Sep 17, 2011
Micoman
  • 198 Answers
SOURCE: After power on beeper beeps
error: 9 beeps is ROM checksum
Turn OFF the PC
1.- Clear the CMOS (jumper near the battery)
place the jumper in 2-3
return the jumper to normal position
2. Remove the battery
Turn on
enter to BIOS
Update bios from the Gigabyte web page
remeber rate my answer,,
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Posted on Sep 20, 2011
No disply no beep
Hi there
If you have checked all the external connections like power and VGA cable etc and they are all working and the monitor is known to work with other computers, then the "no beep" would appear to indicate a fault with the onboard graphics. Check that all the internal connections are firmly established and if this doesn't work you might be able to fit a suitable graphics card into one of the motherboard expansion slots and get a display this way, but otherwise it looks like the motherboard is faulty
Feb 01, 2014 | Gigabyte GA-G41M-ES2L Motherboard
Problem with Gigabyte GA-G41M-Combo Motherboard CPU Wont heat
All information here:
If you mean it can't power up, check the cables and power supply too (PSU).
Aug 29, 2013 | Gigabyte GA-G41M-ES2L Motherboard
Does GA-G41M-ES2L Motherboard support asus gtx 650 graphic crad?
http://www.gigabyte.com/products/product-page.aspx?pid=3500#ov
Specification:
Motherboard chipset;
Intel G41 Northbridge; Intel ICH7 Southbridge,
(The Intel ICH7 is also Intel part number 82801GB)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short)
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
G41, scroll down towards the bottom of the chart.
(Past P45)
Introduced in the last quarter of 2009
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_2.0
The PCI Express 2.0 technology came out January 15, 2007
Means your PCI-Express x16 slot is based on the PCI Express 2.0 technology
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121725
The Asus GTX650 graphics card, (No matter which version), is based on the PCI Express 3.0 technology
PCI Express 3.0 technology is Backward Compatible, with PCI Express 2.0 technology,
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_3.0
"PCI Express 3.0 Base specification revision 3.0 was made available in November 2010, after multiple delays. In August 2007, PCI-SIG announced that PCI Express 3.0 would carry a bit rate of
8 GigaTransfers per Second, (8GT/s), and that it would be backward compatible with existing PCIe implementations."
PCIe =PCI Express
So yes it will work, AND will work at FULL capacity.
Also your motherboard chipset (Northbridge), will support Intel processors that utilize an LGA 775 processor socket, AND up to an Intel Core2 Quad CPU. (Processor)
DOES TAKE SOME POWER, though!
You need a Power Supply that will not only deliver the necessary Wattage, for the computer system; but also need Up To an additional 150 Watts JUST for the graphics card itself.
Know what happens when you try to under power, a powerful graphics card?
Things BURN,
Or
The computer doesn't work
A) The contact pins in the PCI-Express x16 slot, will burn
B) The gold plated contact pins on the bottom, of the graphics card will burn
C) The graphics card requires more power, than the PCI-Express x16 slot can deliver.
A PCI-Express x16 slot can only deliver Up To 75 Watts.
A 6-pin PCI Express power cable is required.
This power cable can deliver Up To 75 Watts.
If there isn't enough power the contact pins, in the 6-pin PCI Express power cable will burn.
So will the contact pins for the power cable, on the graphics card.
The motherboard by itself requires 120 to 150 Watts.
Depending on Processor, Up To 130 Watts.
For each stick of Ram Memory add 25 Watts
25 to 30 for each Optical Drive. (CD/DVD drive)
2 to 3 Watts for each fan; to include the Processor fan, and computer case fans.
Now add 150 Watts for the graphics card.........
For additional questions please post in a Comment
Regards,
joecoolvette
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Southbridge_9xx_and_3.2F4_Series_chipsets
May 04, 2013 | Gigabyte GA-G41M-ES2L Motherboard
After power on beeper beeps 9 times and computer doesn't working. What is it? Motherboard ga-g41m-es2l
Turn OFF the PC
Turn on
enter to BIOS
Sep 20, 2011 | Gigabyte GA-G41M-ES2L Motherboard
Where would i get GA-G41M-ES2L driver
Sep 17, 2011 | Gigabyte GA-G41M-ES2L Motherboard
How can i change intel chip on my gigabite motherboard
Try this . Explains quite a bit. http://www.iusermanual.com/motherboard/gigabyte-ga-g41m-es2l-motherboard-manual.htm
Feb 17, 2011 | Gigabyte GA-G41M-ES2L Motherboard
8-9 bios beeps then shuts off restarts and more beeps
There is a problem of your devices attached to your motherboard, it could be the memory. Remove the memory card and then clean the pins with an eraser of pencil and put it back. Remove the graphics card and when the system boots then probably the graphics card is doing the problem but when the problem still persist then your memory card does the problem.
Oct 25, 2009 | Computers & Internet
Gigabyte GA-G41M-ES2L Motherboard Logo
50 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
