Question about Eclipse Has difficulty HDD Navigation AVN9902HD
Howto operate gps to english - Eclipse Has difficulty HDD Navigation AVN9902HD
Changing the instruction to english
You do not specify what make and model for your GPS and that does not make things easy for us.
Here is a generic answer.
Bring up the menu Change Preferences or Settings. If you see arrow pointing left or right tap arrow in one direction, and keep tapping until you see some icon with flags. Tap the icon. You will see a list of available languages. Scroll down the list until you find English. Select and validate.
If your GPS gives vocal directions, the language will change. Make sure the device has an English computer voice installed.
Dec 30, 2013 | Mio GPS
Howto change the phone language from other language to english
You need to contact your phone's maker to ask them for a replacement rom that is in English.
May 02, 2011 | Cell Phones
I DONT KNOE THE LANGUAGE SETTING.PLS HELP ME.
HI, Change Language of Operating System there is 3 method:- 1) Install in English Instead of using initramfs for booting eeepc use this modified initramfs image:
http://www.roberto.foglietta.name/pub/xepc/en/initramfs.cpio.gz
This setup English localization only if the firstrun does not happen before and the localization would be written down into read-write partition. So this image is useful only during intallation.
2) Automatic Method locale_dialog can do this for you for English. Go to a terminal: Ctrl-Alt-T and type:
/opt/xandros/bin/locale_dialog
A simple dialog will open with a list of languages. Choose your desired language and press OK buttun (it's the button on the left). The system asks for reboot. Again press OK button (it's the burron on the left). Congratulations!
You may want to uninstall Taiwanese software,or programs, or languagepacks to save diskspace (tested on EeePc701). This does not uninstall the English versions or programs! Go here: http://wiki.eeeuser.com/howto:freespace
The above fails to revert all the dialog boxs to english in eee 701 etc - so see the last paragraph of this help page http://wiki.eeeuser.com/howto:configurefromscratch & change the firstrunwizard and remove the .firstrun file and reboot to an english version eee 701 etc.
3) Manual Method
  1. Start Eee PC
  2. Press Ctrl-Alt-T to open Terminal
  3. Type sudo /usr/bin/oowriter /etc/default/locale &
    (Another editor may be used to modify this file.)
  4. Change line to LANG=en_US.UTF-8
  5. Type sudo /usr/bin/oowriter /etc/locale.gen &
  6. Remove the line zh_TW.UTF-8
  7. Type sudo dpkg-reconfigure locales and proceed
  8. press Ctrl-Alt-backspace or Reboot.
It is also possible to change to another language, e.g.
  • Change line to LANG=fr_FR.UTF-8 for French (doesn't work out of the box with these instructions)
  • Change line to LANG=en_GB.UTF-8 for English with UK keyboard-layout
  • Change line to LANG=it_IT.UTF-8 for Italian
  • Change line to LANG=de_GN.UTF-8 for German
  • Change line to LANG=zh_TW.UTF-8 for Traditional Chinese
  • Change line to LANG=zh_CN.UTF-8 for Sim Chinese
More information on language settings can be found in the i18n document.
i hope this will solve your problem.
goodluck
Jan 12, 2011 | Computers & Internet
I'm an american in germany and try to work the garmin but when i switch my map to germany it only works in the german language... any help??
To change the Voice Settings
  • Press TOOLS
  • then SETTINGS
  • then LANGUAGE
Press VOICE LANGUAGE and select an english voice
If your text is also in german
  • Press TEXT LANGUAGE
  • Select ENGLISH
and press OK. When you go back to the main screen it should all operate in english.
Aug 26, 2010 | Garmin nuvi 1370T Car GPS Receiver
E310 and GPS
Before you buy the GPS for your PDA please be careful if the GPS manufacturer guaranteed the functionality with your PDA. I have e800 and I plan to buy the GPS for my unit. Unfortunately at the moment I have no information which one you should you use. You should have a look at the following document, to see how to setup a BT connection to your BT -GPS device. http://aps.toshiba-tro.de/bluetooth/redirect.php?page=pages/howto.html http://aps.toshiba-tro.de/bluetooth/pages/howto/How_to_use_a_Bluetooth_GPS_Receiver_v002.zip
Sep 11, 2005 | Toshiba e310 Pocket PC
Eclipse Has difficulty HDD Navigation AVN9902HD Logo
15 people viewed this question
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
